temp control stuck on cold
Old Sep 15, 2011 | 01:44 PM
team249's Avatar
2000 ram 3500 4x4 cummins turbo. Temp. control is stuck in cold position on either a/c or vents. can go from a/c to vent but nothing happens when i turn temp. control **** from cold to hot. looked at fuse box under the hood an saw a open spot for a relay that said (02 front heater). I don't recall ever seeing a relay in that slot and know I never removed one. Any and all opinions will be greatly appreciated.
Old Sep 15, 2011 | 05:05 PM
VICIOUS FISHER's Avatar
unsure about a 2000 but 0n a 98/99 it is cable actuated, sounds like a broken/unsecured cable......from dash control to top of core/evap unit might have to pull dash (2 hours with cheats) check the back of dash control first.
Old Sep 15, 2011 | 06:28 PM
team249's Avatar
Pulled dash control and found only a plug with 3 wires going to it. Unplugged it to make sure wires were OK, all looked good no loose wires. thanks for your help!
Old Sep 15, 2011 | 07:52 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
aren't they vacuum controlled on those?
I forget. I had an 01, but never had to work on it
Old Sep 16, 2011 | 09:55 AM
infidel's Avatar
Check if the **** is cracked on the back and just spinning on the shaft.
It can feel just like it's turning but it's not.
Old Sep 16, 2011 | 05:25 PM
team249's Avatar
Thanks for the advice, I will try anything. It's getting colder so air cond. or cold vent not welcomed much.
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
04ctd
Sep 14, 2004 04:43 PM
dalef
Oct 18, 2002 04:31 PM
