steering wheel knocking
Old Apr 21, 2005 | 08:56 PM
boatpuller's Avatar
just wondering if anybody had similar steering wheel noises on a second gen. mines an 02. a knocking sort of sound that can be felt in the wheel mainly at low speed turning.lubed steering column u joints,and was able to wiggle the column enough to suspect column problems?out of warranty and no time. so i would guess it would be a pretty spendy show at the shop?
Old Apr 21, 2005 | 11:29 PM
killfast1's Avatar
Check the play in the steering box. Mine has a small pop that you can here from underneath the truck. You can try to adjust the worm gear or you can buy a reman unit from NAPA. I think I heard its about $240 from there.
Phil
Old Apr 26, 2005 | 10:12 PM
boatpuller's Avatar
the knocking sound turned out to be the clock spring.dealer is going to replace under warranty,even though my 3 years is expired.man,a good dealer story for a change!
Old Apr 27, 2005 | 12:20 PM
farmer dave's Avatar
What is a clock spring and what does it do?
Old Apr 27, 2005 | 06:38 PM
vssman's Avatar
Low speed clunk when turning the wheel, heh? I'd suspect the I-shaft has a bit of play in it and is binding on one of the flats. The body flexes causing the I-shaft to move just slightly. They had a similar problem in early 2nd gens. Some lash is OK say maybe .010 - .015" on the shaft after that it's worn out. FWIW, The original manufacturer sells them to DCX for a fraction of what the dealer charges.
Old Apr 29, 2005 | 02:37 PM
boatpuller's Avatar
update,still knocking.clockspring didn,t fix it.dealer wants to replace column,at 1,000 bucks...ouch..vssman i'm going to try to look into your thought on sterring shaft.
Old Apr 29, 2005 | 11:24 PM
KennyG's Avatar
Had the same problem with my '00 and steering shaft was replaced in '02 under warranty. No problem since!!
JVDodge
Jan 28, 2010 04:44 PM
Remnik
May 16, 2008 07:48 PM
LanceK
13
Jul 14, 2006 08:08 PM
unioncreek
Jun 29, 2005 02:00 PM
wantabee
Mar 14, 2004 09:22 PM
