Steering Problem
Old Feb 15, 2009 | 08:11 AM
CB723's Avatar
Steering Problem
I have a 2001 dually and i have alot of play in the steering. I have new tie rods. Would the BD steering box stablizer help or should i just buy a steering box? When I put new tires on the front it help. Thanks for any info
Old Feb 15, 2009 | 06:33 PM
Bluedually4x4's Avatar
Check to see if the box is actually loose before you buy a brace that may or may not help. The box itself could just have loose internals. Try moving the steering shaft with your hand and see if you can find where the play is.
Old Feb 15, 2009 | 06:48 PM
torquefan's Avatar
X2. I would go as far as simply adjusting the sector. That will make a world of difference for the 5 minutes it takes. I've seen plenty of new and reman steering gears that were sloppy and loose too.
Old Feb 16, 2009 | 07:56 AM
Junk Man's Avatar
You need to climb in & under and determine where the play is. Parts are expensive so only buy what's needed. Correct box adjustment procedure is in the FSM.
Old Feb 16, 2009 | 03:24 PM
CB723's Avatar
thanks for all the info
Old Feb 16, 2009 | 03:53 PM
Dave Miller's Avatar
Excellent info...check track bar and tie rods, ball joints for slop. Once you found the worn parts and replace them I would still recommend the steering stabilizer to protect whatever box you end up with but just throwing on the stabilizer won't help if other parts are worn out.
LanceK
13
Jul 14, 2006 08:08 PM
ocsurf16
Mar 13, 2006 09:24 PM
unioncreek
Jun 29, 2005 02:00 PM
OHFarmboy
Feb 25, 2005 11:30 AM
Jun 5, 2003 09:27 PM
