Steering Gearbox leaking now no Brakes
Old Dec 11, 2010 | 06:09 PM
turbomike's Avatar
My steering gearbox has been leaking for a while. When the fluid gets low the pump makes a humming noise and the brake pedal vibrates. I add fluid and it's ok for a while. Today the power steering fluid was a little low and the brake pedal went almost to the floor, barely stopping. I made it home slowly, added power steering fluid still no brakes. The brake fluid was low so I added some, still no brakes or very little braking ability, pedal still goes to floor. It's been raining so I haven't check too many things. Do you think the brake pedal going to the floor is related to the steering gearbox leak or do I now have 2 separate problems. Thanks for any help.
Old Dec 11, 2010 | 07:08 PM
BigIron70's Avatar
Cummins Guru
You have two issues going on. Brake fluid leaking and P/S fluid leaking. You need to find the brake fluid leak and repair that first. Then p/s gearbox replace. Be very careful not to get any P/S fluid in master cylinder just a few drops will cause major problems.
Old Dec 11, 2010 | 10:25 PM
Junk Man's Avatar
You "may" be able to replace the seal on the bottom of the box. My crappy AGR box lost the lock ring at the bottom & dumped fluid causing me to loose power steering. More than likely you need a new box. I suggest trying redhead. Definitely do not get AGR or Cardone. Buy a dss stabilizer with the box. It will help preserve your new box.
Old Dec 12, 2010 | 05:36 PM
turbomike's Avatar
I haven't been able to find a leak in the brakes. The front brake pads need replacing. Maybe the brake fluid level has just dropped as the pads wore out. I have been checking the level by looking at the outside of the reservoir. When I took the top off it was lower than I thought. Could air in the system cause the pedal to go almost to the floor and come back up slowly.
Old Dec 12, 2010 | 06:41 PM
scottsjeeprolet's Avatar
The brake line behind the fuel tank is usually the first to break.
mkinla
Jan 24, 2010 08:57 PM
fsixrider
Apr 5, 2009 07:49 PM
DZLROKET
Aug 13, 2007 09:06 AM
the496rocket
Feb 28, 2007 07:29 AM
DieselJoe
Apr 3, 2006 12:05 PM
