Starter with broken gears. Questions on cause and repair (98 24V Cummins)
Old Aug 14, 2013 | 11:53 AM
Lanceomni's Avatar
The Issue
My 1998 Dodge Ram 2500 24V Cummins would not start. The first three times, it would turn over but would not start. It was audibly normal so I assumed it was unlikely due to a low battery. I thought that it was fuel related.
Unfortunately and after waiting 20 minutes, I attempted to crank and heard a screeching sound similar to a belt slipping. Then the starter spun freely and the engine did not turn.
I pulled the batteries. They were a bit low but could have been from not driving for a while or the four attempts to crank. I charged them overnight.
I pulled the starter. The flywheel teeth looked good; however, I did not turn the engine to see above or below.
The plunger and the contacts were marked; however, they are still relatively smooth and appeared in good shape. In the photos below, you can see the marking. Both the plunger ring and the contacts inside the solenoid are smooth to the touch. Any time I have seen this as an issue is if they look chewed up significantly.
I pulled the starter motor off of the starter and noticed that the spindle's teeth looked slightly worn. Closer inspection of the gears inside the starter case showed three missing teeth.
The question
  1. What is likely to have caused this. I want to make sure I do not screw up the replacement. The rubber on the cable from the solenoid to the starter motor was almost non existent and it could have been shorting itself out. I will have to look at the wiring diagram but could a short like this engage the starter motor prematurely causing the issue?
  2. I have seen rebuild kits for the plunger and contacts. Has anyone successfully replaced components within the starter gear box? The case is sealed with three philips head bolts. Unlike all of the other hardware on the starter, these three bolts are on tight. Any additional effort and I would have stripped them. I could add heat or drill them out.
  3. I have read some pretty bad reviews on aftermarket starters. Any suggestions or recommendations?
Old Aug 14, 2013 | 05:08 PM
patdaly's Avatar
Can't say i have ever heard of the gear reduction gears breaking, but I wouldn't freak out too much just yet.
I personally am running a Napa lifetime new starter, was 235 bucks when I changed it, but that was a couple of years ago. If I had to do it over, I would buy a genuine OEM unit from Larry B at Foster truck.com.
Old Aug 15, 2013 | 09:33 AM
Lanceomni's Avatar
For the sake of time, I have opted to purchase a replacement. I appreciate your advice and comments.
In addition, I have place all of the original components on Ebay. Maybe someone can make use of them.
Old Aug 15, 2013 | 09:50 AM
Tallguy67's Avatar
Lance,
I can see from your post count that you are new to the forum and probably didn't read all the rules.
Ebay adds are not allowed on DTR, so I would recommend you delete the Ebay link before the admins do it for you.
Welcome to the site by the way. There are an amazing number of really helpful and intelligent people here that will go out of their way to help you keep your truck running well for a long time.
Old Aug 15, 2013 | 09:54 AM
Lanceomni's Avatar
Originally Posted by Tallguy67
Lance,
Thank you for filling me in.
Old Aug 15, 2013 | 02:25 PM
Tallguy67's Avatar
Lance, no worries at all, I was honestly just trying to help you not run afoul of the rules. The profanity rules are REALLY strictly enforced, but you don't seem to have any issues there.
Like I said, welcome to the site.
If you have a moment, go to the User CP and fill out your signature with the particulars of your truck. It will really help people to provide you with quick and relevant support and solutions.
FMB
Nov 14, 2010 09:09 PM
tanyj
Jun 1, 2009 08:47 AM
NoSparkplugs
Apr 30, 2008 11:27 PM
93beater
Feb 28, 2007 09:28 AM
walexa
30
Apr 8, 2005 10:26 AM
