Speedometer issues
Old Dec 11, 2009 | 10:54 AM
schoust's Avatar
Speedometer issues
Hey Guy's it seems as though my speedo is going south on me? It started acting up after the last heavy snow storm that I rode all day in? The trany was rebuilt around 10k ago Is there anything that I should be looking for? Or is this a typical issue with a 95 truck of this age?
Thanks
Old Dec 11, 2009 | 11:48 AM
GAmes's Avatar
Your speed sensor is mounted on the transfer case, has nothing to do with the rebuild. If it is working sporadically the little square shaft inside is broken. Not real expensive. Before you pull it be sure to note the mounting position. It DOES matter how it goes back in.
Old Dec 11, 2009 | 05:19 PM
schoust's Avatar
Cool thanks Bud! Can this item be bought at a Napa?Or is it a Steeler item only??Any idea on the cost?
Old Dec 11, 2009 | 05:32 PM
GAmes's Avatar
It has been a few years, but IIRC it was less than $50. Possibly find one in a salvage yard. A call to NAPA or Auto Zone will tell if they carry them.
Old Dec 12, 2009 | 08:21 AM
schoust's Avatar
Thanks again!!
Old Dec 14, 2009 | 08:55 PM
pappyscrapster's Avatar
Hey wanted to add in my problem and solution. My 99 has a VSS or (vehicle speed sensor) located on the top of the rear pumpkin , mine did go bad causing the Speedometer to fail below 20mph, and also manged to keep the ABS as well as the break lights on ( lit in the dash) never did find out if I even had a speed sensor on the tranny. Does your have the rear pumpkin sensor? If so I found one in a junkyard for 20 bucks, been working now for 2 months, (fingers crossed)
8liter
Aug 20, 2008 06:28 PM
97catintenn
Mar 8, 2008 06:18 PM
ridofpwrstroke
Mar 7, 2003 07:08 PM
awmasparky
Feb 9, 2003 01:04 PM
Dodgezilla
Dec 3, 2002 12:16 PM
