softer riding 2500?
Old Jun 2, 2011 | 10:55 PM
coldtaco's Avatar
softer riding 2500?
Anyone try to soften the ride of their 2500? I don't plan on towing anything large/heavy, would like to entertain the idea of figuring out how to soften the ride. Maybe even lower it just a tad, like get rid of the 2" front spacer and make the rear to match. Any problems with removing the spacer between the two leaf packs on the rears? Probably the only way to get softer springs is to get new spring packs with thinner springs and more springs per pack?
Old Jun 2, 2011 | 11:26 PM
nickg's Avatar
google Carli, best thing i ever did on my 2nd gen
lorenz is another well respected choice
Old Jun 2, 2011 | 11:35 PM
rebal's Avatar
could try a kelderman air ride .I have had one on my 90 ever since they came out and love the ride
Old Jun 3, 2011 | 10:24 AM
Midnite's Avatar
I've heard of people just removing a couple of leaves and being very happy with the results. Never tried it myself though.
Old Jun 4, 2011 | 10:57 AM
SIXSLUG's Avatar
A softer riding version of the 2500 is called a 1500!!
Try removing a leaf out back and get the weak springs for the front, I think they are 036's but check the tech section of the Geno's page for sure.
Old Jun 6, 2011 | 12:04 AM
slowflyer2112's Avatar
I would go midpack springs for the rear and variables for the front.
I think dm makes them you can do a search
Old Jun 6, 2011 | 05:42 PM
krowe111's Avatar
What Carli system did you get?
Old Jun 6, 2011 | 05:45 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
I did a set of those double acting rear shackles which worked out real well
Old Jun 10, 2011 | 12:23 AM
nickg's Avatar
starter kit
less swaybar links and shocks(bought shocks later)
Old Jun 10, 2011 | 01:52 AM
krowe111's Avatar
Smile
I am getting a complete Starter Kit installed at the end of July when I am in Edmonton. It has got to make the northern roads a bit easier on my back.
I guess I will know when I return to Yellowknife in August.
Thanks for the information.
Old Jun 10, 2011 | 08:15 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Keep us posted on the results.....Looking at the same thing for my truck..
Old Jun 10, 2011 | 09:03 PM
krowe111's Avatar
Will do.
Just for the record, I have added a PACBRAKE Leveling Kit along with a set of front SUPERSPRINGS SumoSprings to try and improve the ride on our arctic roads. They helped, but not enough.
So since the less expensive option didn't work for me, I decided on a suspension upgrade. I reviewed many options and decided on CARLI as my starting point and selected the Starter Kit to start at.
Old Jun 11, 2011 | 09:14 AM
nickg's Avatar
Will do.
is this for your truck you have listed in your sig or for a 2nd gen?
I own both and can only speak for the improvements on a 2nd gen, my 3rd gen rides better on stock suspension.
if for your 3rd gen call Carli and talk to them to make sure this will do what you want it to.
I too have learned things the hard way,
Old Jun 12, 2011 | 12:34 AM
krowe111's Avatar
It is for a 3rd Gen.
I did a significant amount of research and believe the Carli Starter should give me what I am looking for.
My only concern is that if I get a front bumper mounted winch I may have to up my coil springs to a 6 inch lift to compensate for the weight.
My other option is to get a Firestone Level-Rite air over shock setup.
Only by trial will I know for sure.
Old Jul 28, 2011 | 04:14 PM
high bid's Avatar
Have you changed your spings out yet....results?
