shortbed dually
Old Dec 24, 2006 | 04:45 PM
2broke2smoke's Avatar
shortbed dually
doubled the rear leaves ... lost the blocks
put on a set of third gen ubolts and top plates on to clean it up a little ...
Attached Thumbnails shortbed dually-dually-small.jpg   shortbed dually-dually-small-2.jpg   shortbed dually-dually-009.jpg
Old Dec 24, 2006 | 04:55 PM
Forrest Nearing's Avatar
I love it! C&C rear, correct? would look sweet w/ those flares painted body color
Old Dec 24, 2006 | 05:05 PM
torquefan's Avatar
Wow, that's pretty cool. Would look great with some Megacab style fender flares. Kinda gets my mind working.
Old Dec 24, 2006 | 05:25 PM
correct ...
for others thinking about swapping we had three axles on the gargage floor ...
the cab and chassis was 1" narrower PER SIDE than the SRW ...
which was in turn 1" narrower PER SIDE than the DRW pickup axle
freinds are amazed at how much better it handles than when it had 35's
and how much rougher it rides with doubled springs and 4 ten ply tires
Old Dec 24, 2006 | 05:41 PM
I don't doubt it, my truck felt like it was riding on marshmallows w/ D rated 35's on it
Old Dec 24, 2006 | 06:20 PM
prattman's Avatar
Forrest, Nice job. I like it a lot.
Old Dec 24, 2006 | 06:45 PM
not mine, I wish!
Old Dec 24, 2006 | 07:46 PM
1-5-3-6-2-4's Avatar
Originally Posted by 2broke2smoke
correct ...
Wow, just what I was looking for....... do you have any Numbers for widths on those.
I'm still trying to positively identify the disked D80 I recently picked up.
Thanks
Old Dec 24, 2006 | 07:53 PM
linetrash75's Avatar
I second the mega cab flares I'd love to have a set of them on mine wonder if the boby lines are close enough to make it look decent?
I do like the c&c rear under there I thought frame was narrower on c&c and tires would rubb the springs.
Jed
Old Dec 24, 2006 | 08:17 PM
Demon ... sorry don't remember the widths ... but you aught to be able to just measure the distance from the spring pads to the backing plates on your truck and compare to the 80
linetrash79 ... frames are the same width ... at least on my father in laws '01
Old Dec 24, 2006 | 09:00 PM
See he's the thing....... no ones been able to tell me where the width difference is found.
Is it in the axle tube length? (pumpkin to backing plate) and the hubs are all the same.
Or are the axle tubes all the same and the hubs are different widths......
I know the GM corp 14bolt FF has interchangable hubs.....from single wheel to DRW
Old Dec 24, 2006 | 10:13 PM
i had a srw dana 70 ... so the hubs were different
the two drw axles that we had were both '96 model dana 80s
so were identical except for the axle tube lengths ...
this probably doesn't help you but i thought i'd throw it out ...
good luck and post whatever you find ...
Old Dec 24, 2006 | 10:55 PM
torquefan's Avatar
From what I understand, the difference between a pickup and a c&c is the distance between the spring perches. Additionally, there is a difference between SRW and DRW in the spindles, as well as the hubs.
Old Dec 25, 2006 | 12:41 AM
prattman's Avatar
My bad Forrest. 2broke2smoke, Nice truck. Looks awsome. -Glen
Old Dec 25, 2006 | 01:07 AM
BTW 2b2s..........I dig it....thats exactly where mine is headed
