Shock problems - Need help!
Old May 11, 2011 | 09:37 PM
bairwin's Avatar
Arrow Shock problems - Need help!
Hello. I have a 1997 Dodge Ram 2500 12V Diesel 4x4 extended cab. I recently replaced the front 2 shocks and steering damper. Before replacing them, whenever I hit a large bump the shocks would bottom out. Also quite often the front left wheel would begin to bounce up/down uncontrolably whenever I hit some rough roadway. I replaced the front shocks thinking this would solve my problems. I replaced them with two new Monroe Reflex 911193 shocks (for 8800lb GVW). Now the ride is much better. The shocks don't bottom out whenever I hit a large bump, however, the left front tire still occassionally begins to bounce up/down uncontrolably when I hit some rough roadway - although not as much as before. Question - What am I missing here??? All ball joints were changed approx 2 years ago and I don't believe there's a problem here. The tires are fairly new and balanced properly. I can't see or feel anything loose on the front end. I was thinking of trying the Monroe Gas Magnum shocks before panicing and taking it to the shop. Any advice would be appreciated! Thank you.
Old May 11, 2011 | 10:08 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Best I can say is look up death wobble and go from there.
Old May 12, 2011 | 09:51 PM
SIXSLUG's Avatar
Yeah, buddy, that's death wobble.
Shocks are a small piece of what needs to be addressed. You are probably looking at a trac bar, ball joints, tie rod ends and an alignment to completely cure it.
freight train
22
Mar 25, 2013 04:46 PM
CrashCade
May 29, 2009 08:55 PM
stumpjumper
Aug 21, 2007 07:14 AM
jeephauler
Mar 25, 2007 03:44 PM
racergreen
Mar 28, 2004 03:34 PM
