Shock Mounting Bolt - Help with Bolt Sizes
Old Apr 10, 2014 | 09:15 PM
FordTrax's Avatar
I have a 1999 Dodge Ram 2500 CTD - I have ordered KYB Monomax shocks to replace the original stock shocks - the truck only has 93K on it. I figure I should replace the mounting bolts and nuts they look a bit rusty. But I don't know what size bolts it needs.
They look like flange bolts to me - if I cannot find flange bolts I will just use a 2nd washer.
Anyway, can someone let me know what size bolts I should pick up at the hardware store - I was going to get Grade 8 in the appropriate size(s).
For the Front - it looks like I only need the lower bolt or bolt and washers. I don't think I need a top - is this correct? If so what size bolt should I buy?
For the Read - it looks like I need upper and lower bolts. What size(s) of bolts do I need for the rears?
Thanks for the assistance!
Old Apr 11, 2014 | 08:20 AM
patdaly's Avatar
All 3 show the same in the parts manual, they are M14X2.0 X 80 MM long. If you need it, the Chrysler part number is 06502818
And yea, your new shocks will come with a new nut for the stud at the top.
Old Apr 11, 2014 | 07:23 PM
FordTrax's Avatar
thank you sir
I picked up 6 14mm 2.0 80mm Grade 8.8 bolts and nuts. Got 10 1/2" washers that slipped just nicely on the bolts so I should be good to go. Dodge wanted almost $8.00 a bolt I expect they were flange bolts so I would not have needed a washer - but I got bolts for about $3.00 from the hardware store and washers were only .25 each. Thank you for the assist.
Old Apr 14, 2014 | 09:07 AM
patdaly's Avatar
You will be fine, but be aware grade 8.8 isn't equivalent to a grade 8 SAE, it is closer to a Grade 5.
You would want grade 10.9 to get to a SAE grade 8.
I don't know if the original bolts in there were 8.8 or 10.9.
Old Apr 18, 2014 | 08:47 PM
FordTrax's Avatar
Got 10.9s
I found 10.9s at a local supplier so I am definitely good to go now. Thanks
freight train
22
Mar 25, 2013 04:46 PM
CrashCade
May 29, 2009 08:55 PM
stumpjumper
Aug 21, 2007 07:14 AM
njmaier
May 20, 2006 11:00 AM
vansmack
Jan 8, 2005 10:44 AM
