Seat fix
Old Apr 15, 2009 | 11:07 PM
Yellow Yota's Avatar
Seat fix
Well, I'm sure a lot of you know about this, but I'll mention it for those that don't.
Like lots of you Dodge owners, I was suffering from the common driver's side seat break-down. Mine wasn't bad by any means, but i was starting to notice the difference between the right and left sides of my driver's side seat bottom cusion. The outside was starting to break down from sliding out of the truck. To the point that the fabric was beginning to get a small rip.
The fix is too easy. Get a 10mm socket and a ratchet, a beer, and about 20 minutes of your afternoon.
If you look under the seat, you'll see the four bolts that hold the bottom cusion to the seat frame. Simply unbolt the seat bottoms and swap the passenger and driver side out. You won't believe how much more comfortable the passenger seat is, and it will look better, too.
I also pulled the plastic trim off of the outside of both seats and tightened up the brackets that the plastic attatches to. It took out some wiggle, and got the plastic to fit up to the cusion better.
There you go. Now have a second beer.
Old Apr 15, 2009 | 11:35 PM
wilsonoo56's Avatar
Thanks for the very helpful info. on the seat, I been wondering how to fix the seat, hopefully the wife doesn't notice:
Old Apr 16, 2009 | 09:23 PM
wilsonoo56's Avatar
switched the seats today and they work great, what difference...thanks
Old Sep 2, 2009 | 11:26 PM
albacore's Avatar
Will this work on a "96 club cab? Mine look like the seat back is integrated with the bottom.
Old Sep 2, 2009 | 11:51 PM
littlebuddie's Avatar
I love it - let the passenger suffer for once!
Old Sep 3, 2009 | 10:33 AM
CarlJensen's Avatar
While you have the cushion out put some cheap carpet or the like between the foam and the springs and wire holding it up. Seat will last a lot longer!!
Old Sep 3, 2009 | 01:26 PM
albacore's Avatar
So.....does that mean it will work on my "96 club cab? I like the carpet idea. makes a lot of sense. Also- is it just me, or does it seem like my driver's side seat is higher than my passenger's?
Old Sep 3, 2009 | 03:56 PM
Dr. Evil's Avatar
Dont switch the seats - get some 1" foam, pull back the cover install the foam as well as some carpet underneath the oem foam. Youll think your seats are new.
Old Sep 3, 2009 | 04:10 PM
mopar-or-no-car's Avatar
But by switching the seats side for side, you also hide the tears on the edge of the seat because they are now up against the center seat
Old Sep 3, 2009 | 11:54 PM
albacore's Avatar
Question
I agree. BUT....does anybody know if the switching cushions thing will work in my "96???
Old Sep 4, 2009 | 12:02 AM
Sorry I'm not sure, Ive never been in a 2nd gen other than mine lol. If the seat bottom and back are seperate it should work. Go out and look at your seat see if there is 4 bolts holding the bottom on and if it is a seperate piece from the back.
Old Sep 4, 2009 | 12:15 AM
STate's Avatar
Great free mod! That was the first thing I did when I bought my 98.
Old Sep 4, 2009 | 12:21 AM
Dr. Evil's Avatar
I see...mine were in good shape so it wasnt an issue.
Old Sep 4, 2009 | 07:48 AM
blackimpala's Avatar
Not on mine
I tried switching yesterday on my 96. The pass. side has a lever on the door side that when you switch would put it against the center console.
Floyd
Old Sep 4, 2009 | 10:38 AM
albacore's Avatar
Thanks, impala- that's what I was afraid of.
