Sagging seats
Old Mar 17, 2007 | 10:47 PM
OWEN B's Avatar
Sagging seats
I think the left side of my body has shrank or the seat foam is collapsing.What is the best cure for this?By the way new to the board great site!
Old Mar 17, 2007 | 10:58 PM
fbx22's Avatar
welcome aboard. You should add your truck to the signature so we know if its newer or a 1st generation. Could be the seat springs too.
Old Mar 17, 2007 | 11:29 PM
OWEN B's Avatar
Sorry about that its a 98 quad cab 12v 5speed 4x4
Old Mar 18, 2007 | 02:30 AM
Dr. Evil's Avatar
Owen, PM me your email address. Have a seat fix for you.
Old Mar 26, 2007 | 01:35 PM
Bando's Avatar
I have been having back problems since thanksgiving '06. I went to the doctor, got pills, went to the physical therapist, but none of that did ^(&%$&.
Then I noticed that I had the same problem with my truck. I looked under the seat and noticed that all the small gauge wire straps on the driver's side of the driver's side seat were broken and allowing several inches of sag on one side of the seat. I removed the bench seat assembly and bolted up a 14 gauge piece of sheet metal underneath the seat with self tapping screws. I think the dimensions of the sheet metal piece were 8"x14". There is no excessive sag now, and honestly, it is only noticeable on very large bumps/rough terrain.
For a week now, my back has seen major improvement! I am certain that was the root of my back problem.
Old Mar 26, 2007 | 05:37 PM
CSAGrey1's Avatar
Remove your seat cover. Remove the foam seat pad. Wrap a piece of denim, canvas, burlap or any other heavy material around the frame. You can use steam your original foam seat pad halfway back to shape and add more foam (available from upholstery shops, fabric shops, Wal-Mart etc..) purchase a new foam seat pad from the dealer, or switch the foam seat pad that is broken down with the passenger side pad. Unless the carriage under the seat (the steel wire) is broken your seat is now fixed. If the wire is broken it is fairly self explanatory on how to fix it or they can make you one at an upholstery shop.
92smokin blacky
Nov 6, 2010 10:17 PM
williamdr
13
Oct 20, 2007 09:39 PM
19
May 3, 2004 01:20 PM
loch
Mar 2, 2004 05:45 PM
MARKY MARK
Dec 29, 2002 09:17 PM
