Replacement LED for lower factory driving lights?
Old Jan 16, 2016 | 05:27 AM
high bid's Avatar
I replaced the factory headlights lights with Spyder and it's an overall improvement. What about replacement of the lower driving or auxiliary lights...is there a "plug/play" LED replacement or aftermarket item?
I'm looking for LED 48-55watt mainly something that will plug directly into the factory plug so I don't have to run new wiring and switch.
Appreciate the ideas and replies!
Old Jan 16, 2016 | 02:07 PM
KATOOM's Avatar
Spyder has many fog lights on their website for 2nd gen Dodge Rams but for some unmentioned reason they say they dont fit the turbo diesel. If you like their headlights then I'd be calling them up and ask why the dont fit the Cummins trucks. Seems odd since there isnt anything really that different in bumper configurations and space.
Old Jan 27, 2016 | 11:33 PM
Rons red Ram's Avatar
I believe the issue will be the corners of the intercooler (CAC) and whatever bracketry they use.
I pitched my OE lights and replaced them with Morimoto LED driving lights. Welded up my own mounting brackets to keep the original mount points, lamp position and angles.
Old Jan 28, 2016 | 02:10 PM
VADSLRAM's Avatar
Superbrightleds.com
https://www.superbrightleds.com/vehi...1351&year=1999
I haven't replaced my fogs yet but I've done most of the other bulbs (and flasher module) using them and it seems to be a good price and good quality.
Basically as the regular bulbs go dead I replace with LEDs
Old Jan 28, 2016 | 03:55 PM
If you're looking for usable light, nothing you can put in the original housing will do nothing other than get rid of a few spending dollars. The housings are novelty lights, nothing more.
Old Jan 29, 2016 | 08:28 PM
high bid's Avatar
Rons...are there any aftermarket that easily plug into the factory plugs?
jj3500
Dec 16, 2014 10:36 AM
Patriot2500
Jun 25, 2008 08:47 PM
Hoss
Nov 3, 2006 03:41 PM
CHarlan
Aug 6, 2003 08:40 PM
