Replacement Plow LED lights
Old 12-15-2014, 05:50 AM
jj3500's Avatar
searching for a low budget LED light, if those can be used in same sentence.
the ones on my fisher MM2, the bolts are so rotted if i try to loosen to adjust, they will just break.
i'm looking for something not necessarily with the directionals, i only use this for my private street.
Any low budget LEDs that people have personally used. the Ralleye type lights that are like dinner dish size are cool but probably too large and too expensive that high up on the viewing plane.
So anything else goes....thanks
Old 12-16-2014, 03:58 AM
chaikwa's Avatar
When I put plow lights on my loader, I found the cheapest option was a used set on Ebay. Just a thought.
Old 12-16-2014, 10:36 AM
pind's Avatar
Check in to auroral leads. Size for size, cheapest I have found. They use the same cree leds as everyone else, at about 1/4 to 1/3 the cost.
you give up a tiny bit in lumen rating, but for a plow truck they are more than enough.
also check with truck dealers for maxxima lights. Again, low cost for high output. These are what I use on the skidsteer.
MWL-07SP: Rectangular LED Work Light - 1,800 Lumens
arbor x dad
02-14-2011 01:56 PM
Patriot2500
06-25-2008 08:47 PM
Patriot2500
08-26-2007 02:44 PM
Hoss
11-03-2006 03:41 PM
CHarlan
08-06-2003 08:40 PM
Quick Reply: Replacement Plow LED lights
