replacement battery cables
Old Oct 31, 2019 | 01:31 PM
cmp truck's Avatar
Hello,
I am located in Calgary Alberta. Does anyone know of a local manufacturer who makes battery cables? The Dodge dealer wants $400 for a set of four. I need only two, the R hand negative terminal to ground cable and the connecting cable between the R battery and the L battery. This is for a 2002 5.9L Cummins Dodge.
Regards,
Ian
Old Nov 1, 2019 | 04:45 AM
AlpineRAM's Avatar
Welding shop will have the cables, the ends and a press.
Old Nov 1, 2019 | 09:55 AM
texasprd's Avatar
Starter/Alternator shops can often make cables. Make sure they have the crimper that resembles a bolt-cutter (like this - it cold-fuses the strands and end. There are also bench-mount versions) - not the hammer-lug type crimper. And use thick, adhesive-lined heat-shrink to go over the junction between cable and end, to prevent corrosion from starting. I would recommend CustomBatteryCables.com if you weren't in Canada - I have no idea what the cross-border issues are. No affiliation with that business, but I bought components from him when I build my cables.
Old Nov 2, 2019 | 06:11 PM
u2slow's Avatar
Originally Posted by cmp truck
Hello,
Regards,
Ian
Princess Auto can get you started...
https://www.princessauto.com/en/deta...er/A-p8509879e
https://www.princessauto.com/en/deta...t-/A-p8228074e
https://www.princessauto.com/en/deta...gs/A-p8509895e
For more variety, and military style terminals check out a local battery shop, or some online vendors.
Old Dec 7, 2019 | 05:26 PM
cmp truck's Avatar
battery cables
Thanks for the Princess Auto tips.
I was at the shop that does work on my truck. I happened to be in the front when their mechanic came in.
I was telling the owner how I called a dealer in Calgary who quoted me around $1400 to replace all four battery cables. In the spring, I was quoted $140.
The mechanic told me he would make up a new set. The cost to me was $250.
So, saving me the cost of buying the crimper (as I would use it only once), having to running around buying the cable, the connectors et al, I thought $250 was a good deal.
Regards,
Ian
willy wagon
Jul 22, 2019 10:11 AM
elway12
Feb 15, 2017 08:07 PM
AkitaSumo
Jun 19, 2014 02:37 PM
93beater
Sep 8, 2011 02:12 AM
94DK107
May 4, 2008 03:29 PM
