replace or repair?
Old Nov 26, 2012 | 03:47 PM
pwregan's Avatar
replace or repair?
My 1999 is at the crossroad of it's life, here are the issues:
steering rack leaking, vac pump leaking, oil pan weeping, rear diff leaking,water pump leaking, doors need replacing, rockers starting to go,and ball joints are knocking again,the newest symptom- slight miss at hiway speeds- thinking injectors
The cummins has been rock solid and i love this motor- just hit 210k miles- so it owes me nothing- just hard to make the change and give up on old reliable
i am thinking the repair bill would exceed the value of the truck and it may be time to move on- am i being reasonable?
Old Nov 26, 2012 | 05:29 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
It all depends if you could do 99.9% of repairs yourself,then it's worth it....But if you have to outsource the repairs....That's when it gets very costly...And your bank account will have a stroke...
Old Nov 26, 2012 | 07:45 PM
gorms's Avatar
I've been struggling with the same issue, because everything seems to go (or need replacing) around the same time. But then I fix it (need to in order to get decent cash from it anyhow right?) and all is good for a while. And it stinks shelling out for everything at once, but there's always a chance of having to do that with a new truck too, on top of having a monthly payment. So I'm with Dave on this one! Good luck.
Old Nov 27, 2012 | 11:09 AM
infidel's Avatar
If it was a 12 valve I'd fix it up, but since it isn't...
Old Nov 27, 2012 | 12:47 PM
mrclean's Avatar
Here's the way I see it.......
To get a new truck that's equivalent to what I already have, I'd be spending $45-$50k. I can't justify that cost for something that's basically just personal transportation. If I had some sort of business that required a truck (or won the lottery!) then yes, I'd buy a new one. And to be perfectly honest, I really like not having a payment every month......
Old Nov 27, 2012 | 06:44 PM
SIXSLUG's Avatar
If it still runs and looks good I wold just fix the stuff one thing at a time and keep it.
Nothing you list is very serious, I would start with the suspension and go from there...
corygale
Sep 7, 2009 08:24 PM
PeytonMaterne
Dec 4, 2006 03:10 PM
mhuppertz
Oct 16, 2006 04:53 PM
dieselcrazy
Dec 6, 2005 09:18 AM
twhite
May 17, 2004 12:34 AM
