removing track bar - bolt stuck
having trouble removing the track bar on my 1998.5 disel 2500 ram 4x4. any help will be appericated on how to remove drivers side portion. Thank you very much. Roger
If the nut won't loosen use a jack and 2x4 to apply pressure upwards and use a impact to remove the nut. If it comes loose but won't knock out put the nut back on 3-4 threads and hit the nut with the hammer, remove the nut and it should fall out
If you're not going to use the bar end again and aren't worried about the threads just turn your tires hard left and use a long rod or drift and hand sledge to beat it out.
Always leave the tires on the ground when replacing a trackbar.
CTD2001
Jan 5, 2013 11:12 AM
CTD2001
Aug 22, 2009 10:03 PM
