Rear Brakes
Old Dec 5, 2002 | 02:44 PM
Doug I.'s Avatar
Rear Brakes
97' 3500 ext.cab Dually. I can not seem to get any braking out of my rear brakes. I have turned them down, cleaned and replaced mechanisms and springs. I set them up manually, and they grab for a few weeks, then nothing. I try the self-adjusters going in reverse and by depressing the e-brake. I have bled the lines, and they work when I remove the tires and inspect them on the hoist. It seems that all the braking is on the front, and I am warping rotors. Any suggestions. Thank you
Old Dec 5, 2002 | 04:53 PM
richard's Avatar
Re:Rear Brakes
Sounds like you could have a sticking proportioning valve. Try this, open one of the front bleeders and slam the brake pedal to the floor, close bleeder and see if this helps. Sometimes if you bleed the back, the proportioning valve slams to the front side thinking that a rear line blew out.
Old Dec 6, 2002 | 03:52 PM
DHeadington's Avatar
Re:Rear Brakes
You may try to increase the size of rear wheel cylinders go to the cylinders for 3500. This in creases the bore size and adds to the amount of braking from rear. I went with EGR brake kit update and carbon kevlar pads and shoes. This made big braking difference.
Old Dec 6, 2002 | 06:44 PM
dodgeman01's Avatar
Re:Rear Brakes
<br><br>well DHeadington he has a 3500<br>see
<br>but thats alright happens to the best of us. But I'm glad you said it first cause I was about to say the same thing. **** eyes blind in one eye and I see only diesel smoke outa the other
Old Dec 6, 2002 | 07:22 PM
Re:Rear Brakes
can't win them all!!!!!!! You might try calling Glen at EGR brakes very helpfull http://www.earthroamer.com/egr/
even if you don't upgrade your brakes with him he can tell you what problems are. Followed his recomdation and brakes are better then they ever have been
Old Dec 9, 2002 | 03:28 AM
dalton4's Avatar
Re:Rear Brakes
For my rear auto adjusters to function I have to use heavy braking while backing. I mean get on them and forget the usual easy braking while backing. Works for me ... one set of front pads at about 82K and I now have 106k on the clock.<br><br>Jerry
Old Dec 9, 2002 | 09:37 AM
dodgeman01's Avatar
Re:Rear Brakes
I had a heck of a time I went through three sets of pads.<br>and I only put about 20k on each one.<br>I too if I want to adjust the back brakes I have to stand on the stop pedal hardd.<br>Aaron
1992 Renegade
Oct 11, 2014 03:29 PM
2500CTD
Oct 19, 2010 07:10 PM
wildcargo
Nov 29, 2005 04:20 AM
JImbo1
13
Apr 18, 2003 06:44 AM
