Pullout Headlight Switch
ok, ? for someone.... my truck does not have the driving lights, if i were to get some, will the pullout headlight switch found on some trucks plug right in? and if so which wires and where would i tap into for power?
To the best of my knowledge it's like this.
All trucks have the same wiring harness.
Wires for factory fogs are present by the bumper and by the switch.
If the truck doesn't have fogs, therefore doesn't have the pull out switch, it should still have the wiring and connector for the fogs dangling behind the switch.
In theory, all you'd have to do is get the fog light equipped switch from the dealer and plug in all connectors,
plug your fogs into the connectors already by the bumper and voila!
It might be more than just the switch, but the whole switch panel.
phox
phox
upersleder I ordered the OEM foglight kit from the dealer. I told them I did not want a toggle switch and drill holes and all that stuff!! It came with a rocker swich!!! I ordered the factory headlight/foglight switch. I will be installing it soon will let you know how it goes.
I have a rocker switch mounted on a small plate at the bottom of the dash pannels under the steering collumn. it works great for fog lights and is much less expensive than the OEM switch. This setup, as hidden as it is, is not an OEM setup and does look somewhat different than everything else that is factory.
If you are looking for factory, i would suggest the different headlight switch. if you are looking for functionality and reasonably clean appearance at a smaller price, i would try to find an alternate location to mount a rocker or paddle switch.
thats my $0.02
thats my $0.02
mtdoragary
Nov 7, 2013 08:31 AM
jesse123
Jul 8, 2012 09:04 PM
Barryn
Jul 14, 2008 09:30 AM
jlipskoc
Oct 24, 2005 01:16 PM
2nGlenn
Mar 11, 2003 01:51 PM
