Problem getting fuel pressure reading?
Hi,
I recently purchased a fuel pressure gauge ( http://www.genosgarage.com/prodinfo....ULCAN_TEST_KIT )just to make sure that my fuel injection pump was doing ok. I've got an 02' 2500 ctd but only about 36,000 miles. It's using original VP-44.
I'm trying to get pressure reading at the test port on fuel injection pump but I can't get a reading. I've tried tightening the hose down as much as I can on the test port. It still seems to leak a little fuel even when tightened down.
Right now I am just interested in getting a pressure reading. I'm not showing any signs of problems with my fuel pump or injection pump. Truck runs great but I am still interested in getting pressure reading.
Anybody have any ideas or suggestions about what I might be doing wrong?
Thanks
Thanks
I had one schraeder valve I could not get a reading on. Check your fuel filter housing, it probably has a schraeder valve there also. My 01 did. If possible try another gauge setup. The fuel pressure gauge fitting should have something inside to push down on the schraeder valve to allow the gauge to see pressure. Check to make sure it is there. It really shouldn't leak when tightened, so that is probably where the problem is.
Worst case is your lift pump is dead. The injection pump will pull fuel at some low pressure, probably a couple of psi.
Hi,
Thanks
Thanks
You need a permanent mechanical gauge. Even if you have pressure now, you won't know when it drops. Try taking the gauge off & running the end into a bucket. Turn the key & you should see fuel & will know that the schrader valve is working.
6.7L dodge
Mar 28, 2015 09:36 PM
mullishacrew
Mar 18, 2012 12:41 PM
tomsauto
Jan 4, 2003 01:17 PM
Oct 20, 2002 09:19 AM
