Power door lock failure
Old Feb 1, 2005 | 07:09 PM
dwmcneill's Avatar
Where are the power door lock relays located on a 1999 Ram 2500 4wd. I hear the unlock relay clicking, but no lock relay. I removed the panel below the steering wheel, just to find another panel which looks to be connected to several other panels. Before I figure out how to remove this panel, am I looking in the right place for the lock relay? Thanks.
Old Feb 2, 2005 | 09:28 AM
infidel's Avatar
More than likely the problem is in your door with lock linkage. Piviot points get corroded and stick.
Old Feb 2, 2005 | 10:06 AM
dwmcneill's Avatar
The door will physically unlock with the power actuator, just will not lock. Should I still be looking at the linkage? Thanks.
Old Feb 2, 2005 | 02:02 PM
BIG&BAD's Avatar
it could just be the switch on the door
does the other door lock and unlock
seems like you have power to the door locking-unlocking system so i wouldnt mess with the fuses
Old Feb 20, 2005 | 08:51 PM
Mike Perez's Avatar
This is probably obvious, but just incase, My doors will not lock if I have the keys in the ignition and I open the door and try to lock it. For a while I thought I had an intermittent problem with my door lock, until I figuered this out.
Old Feb 21, 2005 | 12:07 AM
high country's Avatar
welcome to my world! I have the same problem with mine, it is the switch but I am too cheap to r&r it cause I have enty de' la no key
dodgetrucker75
Mar 17, 2011 09:15 PM
reb0957
Dec 18, 2009 08:21 AM
Dynocon
Mar 4, 2008 08:32 PM
staarma
0
Oct 25, 2007 12:49 PM
xp8103
Jun 2, 2006 07:00 AM
