OEM Style Trailer Mirrors & Door Panel Clips
Old Apr 19, 2011 | 09:44 PM
Grain's Avatar
Hi All, Bot some OEM style electric/heated trailer mirrors to go on my 99. I also bot the Mopar metal brackets that seem to be needed with them. I have a couple questions before I start, would like to go into it prepared if possible. Does the metal bracket go between the mirror and the door, or on the interior side of the door? I'm pretty sure I'd figure it out when I have it apart, but you never know. Also, knowing me, I'll break a pant load of the retainer clips taking the panel off. Does anyone have a part number (NAPA preferably) or accurate description for the clips? I've gone into a couple shops including NAPA and they have no idea. Show me to their rack of clips and say match it up. I'd rather have a bag or two of clips before the panel's laying in the driveway rather than after. Thanks!
Old Apr 19, 2011 | 09:56 PM
Purplezr2's Avatar
THis should answer your questions
Old Apr 19, 2011 | 10:04 PM
Grain's Avatar
Thanks for the link. The pics aren't showing on my work computer, I'll give it look at home.
Old Apr 19, 2011 | 10:07 PM
Purplezr2's Avatar
Clips you are looking for
I just pulled the corner of the door back at the top when I did mine, worked fine
Old Apr 19, 2011 | 10:21 PM
Grain's Avatar
Perfect, thanks again. I don't do small places well , so I'll probably remove the panel.
Old Apr 19, 2011 | 11:31 PM
sk_oilburner's Avatar
A body shop should have any clips you need
Old Apr 20, 2011 | 11:32 AM
SIXSLUG's Avatar
Bracket goes inside door between door and nuts.
If you are using the factory control switch you may need to pare off some of the plastic sealer on the back side to clear the longer mounting studs.
Don't pinch the wires when threading thru the mirror and door!! This has caused more than one headache. The mirrors have a path for the wires, use it.
Mick-e
Mar 8, 2012 02:37 PM
lovin1stgens
Mar 30, 2011 12:02 AM
97catintenn
Jan 25, 2006 09:18 PM
Patrick Campbell
Jan 2, 2005 10:04 PM
Ram44maR
Oct 4, 2004 04:10 PM
