Not sure it's normal???
Old May 7, 2005 | 11:07 AM
Ricktye's Avatar
Question Not sure it's normal???
Ok, if I step on the throttle when cranking, truck starts right away, it hardly has a chance to even rotate before it starts....... But, a cloud of black smoke accompanies this method. If I don't touch the throttle, it has to turn over quite a few times before it starts. Idle is ~750 - 800.
Also if I feather the throttle at idle or on downshift, I also get a good cloud of (black) smoke.
I know it's a diesel and all, but don't notice this smoke when following other similar trucks. Just wondering???
R...
Old May 7, 2005 | 11:22 AM
John Faughn's Avatar
Is it new to you ? do you know if its had any modificatoins ? maybe its runing more fuel and the timing mite be the bigest part of that if there are no problums.
Old May 7, 2005 | 05:50 PM
Ricktye's Avatar
I haven't done anything to the truck yet, but not sure on the previous owner. I wondered about the timing too, but, $80.00 to get it checked........ Wanted a few more opinions before I "waste" the money........
Actually, other than the "different" strarting procedure and some black smoke, it runs pretty decent............. Course, it's the only one I've driven, so..........
R...
Old May 8, 2005 | 12:11 AM
msing's Avatar
Ricktye that is how mine starts too have read that is the norm for some of use.
Old May 8, 2005 | 08:09 PM
Ricktye's Avatar
Interesting....... One other thing, does yours' idle low until it warms up? Mine idles about 650 RPM for the first five minutes or so then it idles ~750 - 800 rpm.......
R...
Old May 8, 2005 | 09:30 PM
fschiola's Avatar
If you have an auto trans, the idle should br 750-800 RPM with it in drive and the A/C on.
Old May 9, 2005 | 06:56 AM
Ricktye's Avatar
It's a 5 speed, and as I said above, it does idle at `750 - 800 rpm once it's warmed up for a few minutes, but initially around 650 rpm or so when I first start it.......... Maybe they're all like that?
R...
Old May 15, 2005 | 05:53 PM
mulva's Avatar
I have a 1996 and it too idles low until it warms up, at start up around 600-650 and after running for a few minutes it comes up to about 750.
I actually read my owners manual, (something I have never done before) and learned that when starting cold to depress accelerator pedal and hold at about 1000 rms for a couple of minutes. and during this time some smoke may be present. I hope this helps.
Old May 15, 2005 | 09:25 PM
Ricktye's Avatar
Ok, thanks for the ideas. Maybe it's just the nature of the beast!
R...
Old May 15, 2005 | 09:31 PM
fschiola's Avatar
There was a TSB about setting the idle speed from the tach readings in the truck not being accurate. This may be your problem. See if this can shed some light on the matter for you.
TSB
I set the idle on my 1997 and it started easier. I then had the occasion to put it on a scanner I was only 18 RPM too high. So I guess I was pretty lucky. BTW it dosen't idle too much lower when it's first cold. Yours might not be high enough.
Old May 15, 2005 | 09:36 PM
Ricktye's Avatar
Well, from the TSB, being as mines' a manual, it looks like a bit high is better than too slow....... I'll crank it up a bit.
R...
FirstGen1991
Dec 22, 2012 04:24 PM
dodgethis91cmns
Nov 6, 2010 09:19 AM
Turbo-Dodge
Aug 2, 2008 12:06 PM
John Rodriguez
Sep 28, 2005 11:46 AM
Dusty 96
Dec 20, 2002 06:04 PM
