No buS ?
Old Apr 7, 2004 | 12:18 AM
mwilli's Avatar
No buS ?
No buS ! On my 01 2500 this is the only thing my odometer will tell me when try to pull up codes. Truck seems to run fine, but instuments do not work speedo, tac, oil, temp etc. Truck has EZ. Any ideas ?? Thanks.
Old Apr 7, 2004 | 10:51 AM
hlcptr's Avatar
Same thing happened to me, 2001 HO.
I've had this water leak that drips on the driver side by my left foot every time it rains and when the truck gets washed. I washed my truck, then that night we a had a freeze. When I started the truck the next morning, no guages. Thinking the water/freeze combination may be the problem, possibly infecting the electrical stuff under and around the dash, I drove the truck with the heater on full. After 15 minutes of driving, I started to get my guages coming on intermittently, then they stayed on for the rest of the drive. Haven't had a problem since, but I still have to get around to fixing my leak.
Old Apr 7, 2004 | 01:38 PM
AggieJustin's Avatar
Had the same problem with mine. Turned out to be a bad instrument cluster. I could reset it by unplugging the connector feeding the dash, but it started happening so frequently I had to go get it fixed. Not a cheap item...
JM
Old Apr 8, 2004 | 12:12 AM
J BODY's Avatar
The "bus" is the circuit that the modules use to communicate with one another. Causes for no bus can be a short, or a problem in any of the modules using the bus. Some that come to mind are: air bag (acm), anti lock (abs), central timer (ctm), gauges (cluster), overhead (otis), drive train control (jtec), engine (ecm). Takes a good bit of time to find probs like these some times.
Old Apr 8, 2004 | 08:59 AM
mwilli's Avatar
Thanks for the tips , after checking and cleaning plug under dash , plugs at pcm , engine harness etc. problem seems to have gone away. I really appreciate all the info available here . thanks !
Old Apr 12, 2004 | 08:38 PM
mwilli's Avatar
no bus seems to be back. Don't have any guages . Cleaned ,greased plugs. It seems to be intermitent problem, sometimes everything is ok then the next time I start the truck it says no bus and dash does not work except for almost all dummy lights which are on . Any more suggestions ???
Old Apr 12, 2004 | 08:46 PM
Sad to say, that's how mine went. It was an intermittent problem at first. Over about 3 weeks it got progressively worse, till it was almost a full time problem. I could clean and grease the plugs, but it would come back. It turned out to be a bad instrument cluster that had an internal short somewhere.
Old Apr 15, 2004 | 10:01 PM
farmer dave's Avatar
I am having the same problem now. I have cleaned and greased pcm and ecm but didn't help. What do I do next
dave
Old Apr 15, 2004 | 10:09 PM
Trashdawg5050's Avatar
Farmer Dave Pull the gauge cluster and clean and grease the two connnectors
Old Apr 15, 2004 | 10:11 PM
phox_mulder's Avatar
I hope we aren't using everyday grease, but dialectric grease.
phox
Old Apr 15, 2004 | 10:17 PM
I used dialectric grease, some grease they gave me for light bulbs. How do I go about removing and cleaning the gauge cluster?
thanks dave
Old Apr 15, 2004 | 10:40 PM
DODGE4X4's Avatar
It isn't hard just pull off the dash cover and you'll see some screw that hold it in place. Just start taking out screws and you'll have it free. When you get the cluster loose becarful not to rip the wire out the back,,,they were tight on mine... All in all it is very easy
good luck
Old Apr 16, 2004 | 10:10 AM
So I just unhook the wires are put grease on them also? And I jsut remembered that when it did it the first time I was useing the washer fluid, I am sure that wasn't any water in the pcm or ecm connections. I will try the dash tonight.
thanks dave
Old Apr 17, 2004 | 12:34 AM
travjrath's Avatar
ok ... now my 01 auto dash went bad ...whats goin on here??? "no bus" on odo display and ccd on overhead .... ok now the paul harvey.....ive got a RAD box on the truck , and this is what happens when you turn it on ( dash failure ) but now it does it all the time . the rad box apears to be workn perfect , tested it switch on -no defueling , off- defuels as normal... all readings on the wires are good ... so .. do i have a bad dash ?? is there a way to test it ??? help!!!!!!! thanks
Old Apr 17, 2004 | 10:05 PM
I took the dash out and added grease to connections. It could have been there because the dash just pushes into the connectors, would be easy to wiggle around and get a bad connection. Check engine light went off, will see if it stays off though. Crossing my fingers.
dave
