New ignition, still intermittent starting
Old Nov 26, 2010 | 03:43 PM
Dieseldetective's Avatar
1996 2500 125,000mi. When turning the key I have power to everything until I start to turn it over then nothing. I does work intermittently and seems to have a sweet spot. I replaced the the ignition in the steering column and it improved, but still has the issue. Thanks
Old Nov 26, 2010 | 03:54 PM
Silver R/T's Avatar
Try rebuilding your starter?
Old Nov 26, 2010 | 03:58 PM
Not yet, that's my afternoon project tomorrow. I just found it a little strange it got better with the new ignition. Thought it may have been a relay.
Old Nov 27, 2010 | 09:50 AM
blackimpala's Avatar
I see that you are new to the forum. If you haven't already read about the larger starter contacts. Will last much longer than the stock ones.
http://startercontacts.com/
http://www.genosgarage.com/prodinfo.asp?number=LB-R90SS
Floyd
Old Nov 27, 2010 | 09:55 AM
Totallyrad's Avatar
Probably not related but.....on my first gen it developed a similar issue. If the steering wheel was all the way up it would not start. Lower the wheel and all was well. Bad wires in the column is all I could figure.
Old Nov 27, 2010 | 12:17 PM
torquefan's Avatar
When you plugged in the new ignition switch, did you have a good look at the connector to make sure all the terminals fit the pins snugly, and that there were no signs of overheating?
Exekiel69
Jul 15, 2012 07:43 AM
smokester
May 27, 2011 05:31 PM
keithb7
Nov 30, 2008 07:25 AM
Dougs69299
Aug 21, 2004 08:31 PM
hlc
Feb 13, 2004 05:22 PM
