mounting edge jucie display
Old May 7, 2009 | 11:12 AM
REDNECK-WELDING's Avatar
hey where do you guys mount your edge juice display? also where can i get the piller mount that will hole the edge screen? just wondering where you guys mount yours. thanks
Old May 7, 2009 | 11:18 AM
BigDave12768's Avatar
http://www.gautoparts.com/ProductDet...401&click=1021
http://cgi.ebay.com/ebaymotors/Edge-...QQcmdZViewItem
Old May 7, 2009 | 11:38 AM
wlowe's Avatar
Here's how I mounted mine, (post number two). I used a steel shelving bracket about 1/8 of an inch thick, cut the bracket to length and bent it 90 degrees. Attached it with high bond double sided tape. Is very solid, easy to access and still allows the use of my cupholder.
https://www.dieseltruckresource.com/...d.php?t=204500
Old May 7, 2009 | 11:50 AM
you used tape on both ends? looks good
Old May 7, 2009 | 09:22 PM
wlowe's Avatar
On the end that attaches to the dash I used 3M VHB, (very high bond), double sided tape. You can find it pretty cheap on Ebay.
The bracket gets narrower on the display end so I took a piece of flat 1/8 inch aluminum the size of the box and used some more VHB tape to attach it to the bracket. Then I attached the Edge Attitude to the aluminum with some heavy duty velcro that came with the custom case that encloses the Attitude.
For me, it's the perfect location, easy to see/reach and since I'm right handed it's very easy to press the buttons.
Old May 7, 2009 | 10:03 PM
Doj Dewd's Avatar
i don't have a juice monitor, but i used this bracket to mount my satellite radio
http://www.bracketron.com/index.php?...catid=2&pid=11
i'm sure it could be used for the edge monitor, especially if it has female threads on the backside - or you could adhesive velcro.
i see you are in bc. when i was trying to find one of these in canada - i came across multiple distributors in bc (as per the website i linked). i called them and they gave the name of a place to buy here in calgary. it must have been my luck day because i payed $30 CDN for the mount here locally in calgary. i see the manufacture lists MSRP as $40 US!
hope this helps
Big Smoky
Aug 21, 2007 10:11 PM
O5DodgeRam5.9
May 14, 2007 01:44 AM
BMalone
Oct 29, 2006 08:19 AM
jj3500
Aug 20, 2005 08:12 PM
