Map Sensor
Old Apr 11, 2007 | 11:52 PM
dieselsmoke20's Avatar
Map Sensor
What does unplugging the MAP sensor do on your dodge? I have an edge juice with attitude will it cause any problems on my 98.5, also do you just leave all four plugins unplugged? Also will it affect any idoit gauges or stuff in my edge?
Last edited by dieselsmoke20; Apr 12, 2007 at 12:25 AM. Reason: didn't put enough info
Old Apr 11, 2007 | 11:57 PM
01smoker's Avatar
You must a have a box of some kind on it like an edge box first. What it will do is give it full fuel at no boost and cause it to smoke alot more down low and even just revving it up will cause it to blow a big cloud out. It worked on my edge drag comp on my 01, but I don't what other boxes will do this too.
Old Apr 12, 2007 | 12:06 AM
tx_2500's Avatar
stock? youd be runnin like crap. on certain box's like a comp box youd be blowin some pretty good smoke. dosent work on very many modules tho. even those with boost foolers like the juice
Old Apr 12, 2007 | 09:04 AM
J Lent's Avatar
It will set a code, but no check engine light....you will need a scanner to clear it. If you have a scanner.....unplug the map sensor plug from the map sensor [1 plug] & that is it.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
