Male to male brake line elbow
Old Sep 27, 2007 | 05:39 PM
~Angry Tractor~'s Avatar
I need a 3/16 elbow to finish up this brake line job. I need to connect one male line to another male line with a 90 degree elbow and cant find one anywhere. Anyone know where I can get one. The only ones I can find are reducing elbows or elbows with compression fittings. I dont know how well compression fitings and brake lines go together? Doesnt seem right to me. Thanks.
Old Sep 27, 2007 | 06:14 PM
patdaly's Avatar
I have never seen such an animal, not to say it does not exist. You may have to put a loop in one of the lines and make the other bend around for the 90 and then use a straight union to connect the flare fittings.
As for compression fittings? I have seen ASE certified mechanics use them in brake lines, but there is no way on gods green earth you would catch me doing that. I guess I am just too paranoid, but then again, I am still alive!
Old Sep 27, 2007 | 07:33 PM
Number47's Avatar
using compression fittings on brake lines is illegal. its not DOT appoved
Old Sep 28, 2007 | 01:18 AM
Deezel Nate's Avatar
A hydraulic line shop will have what your looking for. OR possibly Napa, Carquest, etc. They usually have some brake fitting stuff.
Old Sep 28, 2007 | 03:48 AM
OK thanks guys. Yeh I had a feeling that compression fittings weren't meant for brake lines. Funny how O'Reily's is more then happy to sell you them for brake lines. There is a hydraulic shop near work, I'll try them. If they don't have the elbow then I will get some unions and another short run and loop it. I was thinking of doing that but wasn't sure how a loop would do in a brake line. Plus a 90 elbow would make the job look more professional, but I'm getting desparate to get this truck on the road.
Old Sep 28, 2007 | 04:28 PM
bent valves's Avatar
After spending weeks searching all the local stores and big online stores for a brake fitting, Fedhill had what I needed: http://www.fedhillusa.com/?page=home
If you look around at their fittings you might see something that might work.
Old Sep 28, 2007 | 07:17 PM
I found something that worked. Now I just have to figure out why the brakesaresinking to thefloor. I bled them with my mighty vac so Im pretty sure I got all the air out. Every nowand then the abs light will come on when I press the pedal down fast. It stops good ou just haveto go all the wayto thefloor. Something isnt right though. Ill do a search here and see what I turn up. Anyone knows any links to this topic let me know. Thanks.
Moules
Jan 2, 2009 09:58 AM
qwest
Sep 9, 2006 04:40 PM
greenwing
May 15, 2006 08:24 PM
drew03
Nov 18, 2005 02:46 AM
