Luke's link gone bad! Need advice about replacement track bar!
howdy, everyone
I am the proud owner of a grail! All in all, I like the pickup, but I had an interesting experience today. While turning into a parking lot, I heard a pop. I didn't think much of it, but one of my passengers stepped out and immediately found a part on the ground. As it turns out, the shiny metal part of the lukes link on the track bar had broken in half.
I called the dealership (specializes in used diesel pickups) and talked to an owner, who said that he had installed many of these and has never had a problem like this. But, on the other hand, some searching around here leads me to believe that the Lukes link may not be ideal for rough usage.
The dealer is coming tomorrow to pick up the rig and repair this as well as some other things. I just need some advice about which route to go with so I can discuss it with him. I have been looking into a moog track bar and I am also interested in any other product that would work well.
Thanks in advance for any advice!
I put in a Solid Steel 3rd gen Adj track bar and DSS (Dodge Steering Stabilizer) for the steering gear. My Luke's Link kept loosing up so I replaced it. I'm happy with the SS track bar but it is pricey since you have to also buy the adapter bracket to install it.
http://www.sourceautomotive.biz/inde...d=20&Itemid=49
There are other track bars like Thuren Fabrications:
http://www.thurenfabrication.com/products.html
These are 2 of the most talked about track bars but there are some others. Some go with the Moog or stock but you still have the ball joint failure later. The 3rd gen track bar eliminates the ball joint and replaces it with a bolt thru bushing. The Solid Steel bar requires the $200 conversion bracket and then uses a bolt thru 3rd gen type bar. Thurens 2nd gen bar replaces the ball joint with a heim joint and costs about $300.
I'd recommend the 3rd gen bar if you can spring for $500+. Happy shopping.
Dave
Dave
Thanks for the quick response, guys! Unforutunately, the solid steel bar will probably not work out. However, the Thuren's might be agreeable for the dealer.
Is the moog unit prone to failure, or will it last quite a while?
I got the Rare Parts track bar. Its adjustable, and over twice the size of OEM or Moog.
http://www.trucktrend.com/features/g...bar/index.html
Why don't you do the bar yourself? It's really not a hard job....coming from a DYI'er prospective. I was a little afraid when I tackled it but it turned out easy.
Good Luck whatever you pick.
Dave
The pickup needs other work done, the dealer was in the area today, and he will do the work for free. There is a moog in stock at a local parts store, but this broke yesterday and the pickup is already on his trailer and gone. Also, the dealer is curious about how the Lukes link broke and wants to look into it further, since this is the first time that this has happened and he has installed many fo these. The NAPA unit sounds like a winner, since it has a lifetime warranty and will be easy for me to find.
He is a curent thread todfay of someone who had a NAPA bar last 2 years and needs replaced. Save your receipt.
https://www.dieseltruckresource.com/...d.php?t=212320
Another reason to do the 3rd gen bar ONCE and get it over with or you will be doing it again in a few years and it contributes to the "death wobble". These stock type track bars just don't cut it with our heavy Cummins engine and front end.
There's a reason Dodge switch to the 3rd gen bar.
I have over 300K miles on my truck, and I have had to replace the original bar, with another OEM one, then I had to replace that one later with a MOOG. The Moog has probably 150K miles on it, and it is still doing fine. I drive on all kinds of terrain from farm to work, and don't baby the truck. I can't see spending all the extra money on the 3rd gen stuff, when the NAPA will probably do. Also, I think the Napa & Moog are the same unit, but I am not 100% sure.
Thuren tac bar. The ends are rebuildable for under $100 for the parts, no realignment req'd, hell for stout. Mine's been on over a year and is solid as a rock.
The lifetime bars are good for their lifetime, not necessarily yours or your truck's. These parts help carry the store as you'll probably pick up tools, rags, spray lubes and scented christmas trees every time you trade out a lifetime part, creating small profits for the store.
1500 bucks is a fee I hope to only have had to pay once for a front end rebuild which probably started wearing out due to a crummy trac bar, hence I replaced with a Thuren, which is only about a hundred bucks more than your lifetime bar.
Kurt
Kurt
Thanks for the info, guys! As mentioned, after talking to the dealer, I will probably opt for the free LL for now. If that doesn't work out, I will be looking at the other options mentioned here.
I will use the thing for towing and offroad farm work. However, it will never have a lift, leveling kit, large tires or a snowplow, if that makes a difference.
