Loose mirrors
Old Aug 6, 2007 | 10:53 PM
eb290's Avatar
Loose mirrors
A friend of mine has just bought a 97 1-ton. He says it is in really good condition except that the side mirrors are loose. They will move in while going down the road. They are the chrome mirrors. I believe he will have to take the door panel off, but I'm not really sure. I had a 95 one ton but that has been to long ago and I never had that problem. Can anyone give some help on this problem.
Thanks,
eb290
Old Aug 7, 2007 | 06:34 AM
WVAussie's Avatar
I have the chrome mirrors also and had the same problem. I took the mirrors off and peeled back the foam seal, there are two screws that secure a metal tab under there. Remove the screws and tab and you will see the rectangular pin that locks the mirror in position. I removed the locking pin and cut some shim stock, I think it was .006 wrap it around the locking pin and push it all the way into the locking pins seat put it all back together. Really tight now.
Old Aug 7, 2007 | 11:13 AM
vssman's Avatar
I had similar problems on my 96. As stated above, the door panel has to be removed to access the hold down bolts for the mirror. I found the 'clamp' screws stripped. Drilling and retapping (adding a nut to the back side where room was available) fixed mine. You want them tight but not so much that they'll cause damage to the door if hit.
Old Aug 7, 2007 | 11:59 AM
eb290's Avatar
I thank you all for the information and will send him a link to this thread. Maybe he will join the forum and have some comments and or questions about his new ride.
tswan
Jun 2, 2010 12:14 PM
Leaky Gasket
Aug 14, 2008 07:17 AM
BigGameJames
Feb 1, 2008 11:58 AM
kully560
Jan 2, 2007 05:26 PM
moopa
13
Nov 6, 2002 11:10 AM
