Looking for feed back on "LUKES LINK"
Old Jan 11, 2009 | 08:55 AM
nickg's Avatar
As the title states, I'm looking for feed back both good and bad on Lukes links.
I've read all the posts on 3rd gen Mods, so I'm well versed in that, so for now I'm just interested in this repair thanks.
Nick
(I posted this on the Cummins forum as well)
Old Jan 11, 2009 | 09:09 AM
high bid's Avatar
The part has worked well for my track bar, no issues.
Old Jan 11, 2009 | 10:28 AM
infidel's Avatar
I have a lifetime warrantied trackbar on my own truck, bought it way before Luke's was around but have installed several.
No complaints. Only one has come back to be retightened.
Local diesel shop says they won't touch Luke's due to liability issues.
Old Jan 11, 2009 | 02:21 PM
smokinram99's Avatar
no issue even here, afeter one year! I think its a good replacement product and works well. its also more durable, poly versus OE rubber bushings.
rob
Old Jan 11, 2009 | 03:45 PM
smokeyram's Avatar
lasted longer than a stock track bar. but eventually failed.
Old Jan 11, 2009 | 03:48 PM
Dave2001's Avatar
I put it on a cheap track bar and the rubber bushing went on the axle end. I thought that it was because I had the Luke's Link end tight. I then installed it on the OEM track bar several months ago. Alignment shop tightened it up like I had it on the first bar. No problems to date.
Old Jan 11, 2009 | 07:06 PM
slim51015's Avatar
Had mine on for about 5 years. Still tight.
Old Jan 12, 2009 | 12:20 AM
Russ Roth's Avatar
Same here.
Old Jan 12, 2009 | 09:08 AM
blackimpala's Avatar
I give it a good report. Mine has been on for about three years w/o any adjustment. You do get adjustment washers w/the link but mine hasn't needed them yet.
Floyd
Old Jan 12, 2009 | 09:25 AM
kawi600's Avatar
I did all my steering linkage joints with them and theyve held for a couple years now. No problems.
Old Jan 13, 2009 | 10:45 AM
michcumm's Avatar
Have two 2nd gens with Luke's tie rod/track bar ends on them. have over 70K miles on one and no problems. Only complaint is the one hits the front diff cover. ( I need a leveling kit.) Great customer service as well!
Old Jan 13, 2009 | 09:46 PM
nickg's Avatar
Thanks for the posts! so far between this site and the other I've only seen one negative report
keep 'em cummin ( get the pun?)
Old Jan 14, 2009 | 06:49 AM
jfpointer's Avatar
I had one on my stock track bar for about 20,000 miles but got tired of tightening it all the time, so I bought a Thuren track bar.
Old Jan 15, 2009 | 12:17 AM
wcbcruzer's Avatar
I've got one on my trackbar right now. It fixed it. Unless you're offroading I think it works great. Only downside is that it takes more time to install the Luke's link than installing the trackbar. That end bushing doesn't want to come out either. I put it between a bottle jack and the frame of my truck and it started jacking up my truck before the bushing came out. Finally I jerked it a few times and it blew out.
Old Jan 15, 2009 | 09:28 AM
I have a 60 Chevy that I rebuilt the front end. The bushings had been in for so long that I had to put lighter fluid on them and burn them out.
Floyd
