Jumpy Tach
Old Jul 18, 2003 | 09:44 AM
sixtogo's Avatar
Jumpy Tach
This is a strange one. Every so often....not YET enough to tear into it, the tach in my '95 jumps up and then will go to zero. This is random and engine RPM does not seem to make a difference. Does the sensor on the dampner (crank pulley) have a history of going bad? Where would you begin?<br><br>TIA<br>Michael
Old Jul 18, 2003 | 10:03 AM
rattle_rattle's Avatar
Re:Jumpy Tach
I think I would start by doing the instrument cluster diagnostic check. Hold the trip/odometer button in while turning on the ignition key. It will go through the diagnostics and give you a code if there is something wrong. If that checks ok, then the sensor is the next step. However, if the problem is intermittent, you might want to do the diagnostic at a time when it's acting up.<br><br>Gary<br>
Old Jul 18, 2003 | 12:46 PM
Cumminsdude's Avatar
Re:Jumpy Tach
[quote author=rattle_rattle link=board=5;threadid=17237;start=0#161373 date=1058540597]<br>I think I would start by doing the instrument cluster diagnostic check. Hold the trip/odometer button in while turning on the ignition key. It will go through the diagnostics and give you a code if there is something wrong. If that checks ok, then the sensor is the next step. However, if the problem is intermittent, you might want to do the diagnostic at a time when it's acting up.<br><br>Gary<br><br>[/quote]<br><br>Hmmm thats intersting? Do you hold the trip/odometer button in while you are starting the truck or just so that the ignition is to the on position? It sounds cool, I think I am gonna try it as long as I can't mess it up too bad!!!
Old Jul 19, 2003 | 04:37 PM
Tackett's Avatar
Re:Jumpy Tach
Um, on my '97 the trip computer is 100% mechanical, so I assume it's the same on the '95. <br><br>Is that a trick that works on the 98.5+ trucks?<br><br>BTW, mine does the same thing, and I'm guessing it's the crank position sensor.<br><br>Tackett
Old Jul 19, 2003 | 06:17 PM
Re:Jumpy Tach
Oh yeah, you have to have the digital odometer. Sorry my bad. I tried!
Begle1
Sep 23, 2008 06:59 PM
stroker4501
Mar 16, 2008 09:24 PM
cuccamonga
Oct 27, 2007 07:10 AM
tallzag
Aug 24, 2007 05:56 PM
pimp_one60
Aug 15, 2005 08:34 AM
