Intermitten A/C Problem
Intermittent A/C Problem
Hey guys, I would like to hear from some of the A/C gurus out there. My problem is that my A/C has become intermitten. Sometimes it works and sometimes it don't. The problem is almost certainly an electrical problem. I have checked the pressure switches by using an ohm meter on the high pressure switch and I have used a jumper wire on the low pressure switch and it does nothing. I have also replaced the compressor, liquid line, and receive drier and still nothing. When it works the pressures are right according to the Chrysler FSM. I have tested the relay in the power distribution center and everything tests out there. I have also pulled the switch in the dash and cleaned it and it appears to test out according to the pinouts in the Chrysler manual. I have also recently put a new PCM in the truck. I know that the PCM cycles the clutch by removing the ground. So, should one of the wires always have a positive 12-volts when the A/C is selected if the PCM cycles through grounding? Any suggestions?
have you checked the power side of the relay? sounds like you have tested the coil side. the 1 wire going to the clutch shud get power to activate clutch. also if you can get a hold of a scan tool when it does and see if the pcm has requested ac on
I have checked the power side. In the power distribution center relay I can take a jumper wire and place it between terminals 30 & 87 and manually cycle the a/c clutch. Or, I can also go to the PCM and manually place a ground to the C-3 terminal #1 designated for the a/c relay and manually cycle the clutch that way. But, it will not do it on its own. I have also checked the grounds associated with the a/c clutch. Also, my ambient air sensor and engine coolant sensor both read normal. What do you all think? Maybe a bad PCM? I just put the new PCM on the truck 1/17/2011. It was a unit that I had O'reilly's to order from A-1 Cardone. Do you all think that could be the culprit?
When I turn the A/C on, the terminal at the PCM that is designated "AC Switch Sense" should be grounded, right? I can use my multimeter tester with the negative to that terminal and the positive to the positive battery post and it shows the exact same voltage as the battery. Now, when I ohm it out (stick my negative to the PCM terminal and the positive to a battery or chasis ground) it reads something like 48-52 ohms. Should it not show continuity? Does that mean anything? I have already checked the ground under the dash that grounds the HVAC control. Thanks!
you mean west of knoxville. i take trips to crossville periodically. ill pm you my phone number and you can do the same. we can meet up when im out that direction next time. unless you are in knoxville from time to time.
Yes, I mean west of Knoxville. You are two hours east of me. That sounds good. I am not in Knoxville very much but if I get over that way I could definitely use another perspective on this thing. This morning I was going down the road and the a/c started working out of nowhere. I didn't hit any bumps or anything. I was travelling on a nice smooth stretch of county road at about 40-45 mph and all of a sudden I feel cold air coming from the vents. So, I pulled over and checked the a/c switch sense and it read exactly the same as it did yesterday when the compressor would not kick on. I also hooked up my pressure guages. It read almost exactly like the Chrysler FSM says. The low side cycled between approximately 23-43 psi and the hight side fluctuated between around 185-200 with the outside temps at 80-82 degrees. And, it was blowing 40-42 degree air with a thermometer in the middle vent. Nothing seems to be different than yesterday when the compressor would not kick on without me manually cycling it. I'm baffled! Any suggestions?
