Interior Overhead Lights and More
Old Aug 17, 2007 | 07:24 AM
91rangerturbo's Avatar
First off how do you remove the overhead storage with the two lights in it? Mine has been bugging me since i bought the truck. The lights are really floppy and bounce around alot turning themselves on. Is there a part that is easily replaceable to fix the floppy lights?
Another my fog lights don't work but the bulb's don't look bad either. What's the best way of trouble shooting these? Is there a fuse or a relay for this?
Old Aug 21, 2007 | 01:17 AM
zfort001's Avatar
When you pull the overhead console out you can unplug the harness to get the console out of the truck. then you will notice that the lights have a small block of plastic that hold the switch and small spring assembly. on my 01 i found that the block had seperated so i used a soldering iron to melt the plastice together so the switch would function corectly. the switch block is white with a black plastic cover.
Old Aug 22, 2007 | 03:34 PM
Cool thanks i am going to check into that.
ehammett
13
Dec 30, 2008 05:20 PM
H8GAS
18
Aug 3, 2007 06:31 PM
Dieseljunkie
Feb 8, 2007 10:17 PM
quantrill88
Apr 17, 2006 06:44 PM
