Instrument Cluster Problem and Alternator NOT Charging!
Old Jan 13, 2008 | 08:02 AM
Katmandu's Avatar
Exclamation Instrument Cluster Problem and Alternator NOT Charging!
I have a 98 Dodge Ram 2500 w/Cummins Diesel. The instrument cluster gauges/needles recently stopped working. All the needles stay pointed to the left when the truck is started. They WILL MOVE about a 1/16" to the right.
When a diagnostic tool is used on the port, it shows NO Computer (ECM). Also, the alternator shows NO OUTPUT when connected to a battery/alternator machine!
The LCD odometer just flashes the mileage. The odometer is NOT racking up mileage when driven. Some idiot lights light up. The ones the do are random.
I checked all electrical connectors I could find under the hood and under the dash. I clean all the battery posts and grounds. My batteries are in good condition as well.
The alternator is NOT charging when the vehicle is driven. I was driving with the lights on and the battery was drawn down.
What's going on and what do I need to check out
UPDATE !! ISSUE SOLVED !!!
Replaced the Crankshaft Position Sensor. (aka CPS)
Last edited by Katmandu; Oct 10, 2019 at 06:27 PM. Reason: Replaced the ESS Engine Speed Sensor or the Crankshaft Position Sensor. (aka CPS).
Old Jan 13, 2008 | 08:39 PM
WestTN's Avatar
Sounds like the CCD buss is not working. You will need a service manual to help diagnose the problem.
Old Jan 14, 2008 | 02:16 PM
Katmandu's Avatar
Question
What exactly is the CCD buss ??
Old Oct 6, 2019 | 06:15 PM
John Cooper's Avatar
What's going on and what do I need to check out ?
Did you ever figure out the problem with the truck I have a 24v Cummins doing the exact same thing as yours and have tried everything I can think of thought I'd ask your out come
Old Oct 8, 2019 | 09:51 AM
texasprd's Avatar
You may not have much luck getting an answer - his last activity was Aug 2018...
Old Oct 8, 2019 | 07:03 PM
Katmandu's Avatar
Talking
I'm still here ! Lurking in the shadows ! Lol!
Replace the Crankshaft Position Sensor. (aka CPS). That's what fixed my old truck's issues.
I MISS MY HOLY GRAIL !!!!!!
Old Oct 9, 2019 | 10:21 AM
texasprd's Avatar
Glad you're still around! lol
Having a 12-valve, where the Engine Speed Sensor (aka ESS, not really a CPS) is only used to count RPMs because the injection events are mechanically controlled (and pneumatically, if you count the AFC), I was curious to see if there really is an actual crank or cam position sensor on the 24 valve and what it does. Found this interesting explanation...
masterphreak
Jun 12, 2017 05:00 AM
McNasty
Mar 10, 2016 07:29 PM
montemorris
13
Sep 25, 2014 10:42 AM
kthiemann
Apr 14, 2013 07:13 AM
hellotbone
May 2, 2003 03:57 PM
