ignition switch
Old Nov 8, 2010 | 08:31 PM
Phillip007's Avatar
ignition switch
I have 94 3500, ignition switch broke, it will turn on everything but the starter. Is there away to hook up a toggle switch for the starter only? This is a farm truck and I don't want to spend the $ on new switch.
Old Nov 9, 2010 | 09:44 AM
infidel's Avatar
New switch is only $29 from Napa.
Might be easier than the hassle of messing with the wiring.
Instructions> http://dodgeram.org/tech/repair/elect/ign_switch.htm
Junk Man's Avatar
Wire goes to small contact on the starter solenoid. You "could" run a fused wire from the battery to a push button switch and down to the starter. I'd check the wire first & make sure that the switch is the problem. You may have the wire disconnected or bad starter contacts. It is usually better to fix something than 1/2 as s rig it but to each his own. Rigging and pp maintenance are the primary reason new $30,000 (or more) vehicles turn into trash.
Cowhand
Sep 21, 2004 10:42 AM
jman
Aug 25, 2004 05:15 PM
jd03ctd
May 10, 2004 08:06 AM
GaCamper
Dec 1, 2003 08:59 PM
D4Fritz
Mar 16, 2003 03:55 PM
