How to check codes
Old Apr 4, 2007 | 03:59 PM
Dangousity's Avatar
How to check codes
I cant seem to find the sticky or in the tech facts how to check codes on a 2002. Does it require a handheld or can you do it buy the on off method, Can someone please point me in the right direction?
Old Apr 4, 2007 | 04:01 PM
dodgezilla04's Avatar
on and off 3 times, back to on. read the odometer. if it says DONE, nothing wrong.
Old Apr 4, 2007 | 04:51 PM
Dangousity's Avatar
what if i dont get anything ? i mean im not dumb but i sure feel like it when it still only just shows the mileage ?
Old Apr 4, 2007 | 05:15 PM
if there are no codes, it will still say DONE. on and off 3 times and back to on.
Old Apr 4, 2007 | 05:32 PM
Dangousity's Avatar
OKz P1693 ... hmm, I don't see that number under tech codes, By the way, I thin k I was going too fast and doing it one too many times.
Old Apr 4, 2007 | 06:13 PM
phox_mulder's Avatar
If all you get is the 1693, you'll need a code scanner to find the hidden code.
Sometimes even those won't spit the code out, and you'll need the Dealerships fancy schamncy code reader.
phox
Old Apr 4, 2007 | 10:28 PM
cumminspower79's Avatar
What sort of symptoms are you having? Most of the time it seems that when these trucks act up its the vp44 injection pump. Thats how and why a lot of people find this site such as myself!
Old Apr 5, 2007 | 09:44 AM
redbeast's Avatar
I think, but don't know that that code is the crank shaft position sensor code.
Take it to the local auto parts store and have them read it. Advanced autoparts is my favorite.
The crankshaft position is an easy fix.http://www.dodge-diesel.org/articles/cps/ckp.htm
Old Apr 5, 2007 | 12:41 PM
NoSeeUm's Avatar
Did you keep watching it a bit longer after the 1693?
Jim
Old Apr 11, 2007 | 12:07 PM
ProspectorTim's Avatar
Easy way: "Honey I need this $600 code reader. It scans & clears codes, the instuction book describes the codes, it calibrates the speedo for different tire sizes, and it saves fuel $$". It's called a SMARTY!
madhat
68
Oct 25, 2015 08:25 AM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
