help apps
Old Jul 10, 2010 | 03:09 PM
ldperrine's Avatar
help apps
i have what i think is an apps problem and will try the reset method later today. i just pulled the codes using the key on off trick and got a p0216. fuel injection pump timing failure. what does this mean and the cure. the truck still runs but does have symptoms of a bad aps from what i have read. larry
Old Jul 10, 2010 | 09:54 PM
ldornak's Avatar
Usually 216 is associated with a dying injection pump. What are your symptoms?
Old Jul 10, 2010 | 11:29 PM
ldperrine's Avatar
2 times now when in cruise controll going 65=70 mph it seems to not keep up. push on pedal and nothing happens, but if i step on it hard it will take off again. that is the only symptom. other than the two times seems to run fine.
Old Jul 10, 2010 | 11:59 PM
mstep3's Avatar
have you checked your fuel pressure? mine started getting sluggish like that when my lift pump started to go down hill & fuel pressure was getting low.
Old Jul 11, 2010 | 08:50 AM
ldperrine's Avatar
fuel pressure is good.
Old Jul 11, 2010 | 01:09 PM
Junk Man's Avatar
Another one bites the dust. Search 0216, VP44, MWFI & do some more research. That said, I bought mine here: http://www.dieselperformanceparts.com/
Good people - took great care when I ran into problems. (It is easy to take care when there are no problems.) Talk to Mark. He owns the place & said they sell lots of pumps (MWFI) but the brand isn't apparent on the site.
HOHN
Aug 19, 2006 09:07 AM
azlineman
Mar 30, 2006 09:29 AM
Big Smoky
Mar 7, 2006 08:13 AM
Mechanos
Jan 21, 2006 07:22 PM
IH8MYCAT
Feb 7, 2005 04:53 PM
