Hazzard lights not working
Old Dec 8, 2012 | 10:59 PM
atthepark's Avatar
The hazzard flasher lights wont activate. All other lights (head lights, blinkers, running lights, cab lights, brake lights, reverse and license plate lights) work fine. I have replaced the underhood fuse, the dash fuse, the hazzard light relay, and the multi-switch on the column and they still dont work. Any ideas? Thanks for any help.
Old Dec 9, 2012 | 12:04 AM
SIXSLUG's Avatar
Check your trailer connector...
Old Dec 9, 2012 | 10:50 AM
NE frmhnd's Avatar
I think there is a maxi fuse under the hood as well, you got it too?
Old Dec 9, 2012 | 02:11 PM
torquefan's Avatar
On the 1996 truck, the hazard lamps have a separate flasher from the turn signals. Are you sure you got the right one?
Old Dec 9, 2012 | 06:36 PM
SIXSLUG's Avatar
maybe the hazard switch...
Old Dec 9, 2012 | 10:22 PM
atthepark's Avatar
I replaced both flasher relays in the fuse box and the fuse in the power box under the hood. The hazzard switch is built into the mulit switch that includes the blinkers, wipers and hi-lo beam and that has been replaced as well. What on the trailer connector should I check?
Thanks.
Old Dec 10, 2012 | 10:54 AM
SIXSLUG's Avatar
Just pull it apart and see if it full of dirt and corrosion, a lot of times this is a good place to find a short or broken wire......
Old Dec 10, 2012 | 10:08 PM
torquefan's Avatar
Looking at the schematic, it looks like one pin of the hazard flasher is supplied voltage from fuse C in the PDC. The other pin of the flasher is circuit L19, a pink/white wire that goes to the multifunction switch connector, terminal 13. The next place in the troubleshooting I would focus on is that L19 circuit. Make sure it has continuity from the flasher socket to the multifunction switch. I am betting that wire is either broken really close to the m/f switch connector, or its terminal is pulled out of the connector.
chucka
Jun 7, 2010 04:35 PM
greenworks
Dec 30, 2005 06:13 PM
2500CTD
Aug 25, 2005 07:53 PM
IA_James
Feb 26, 2005 12:16 AM
hotdram
Feb 12, 2005 11:12 PM
