Hazard flasher not working
Old Mar 13, 2011 | 04:30 PM
Cholmes's Avatar
I have an 02 2500 and I have no 4 way flashers, I have replaced the flasher with a new heavy duty but no difference. My truck has one flasher. I have checked the fuses under the hood and in the fuse panel. If I push the switch the flasher will make one click and stop. Any ideas?
Old Mar 14, 2011 | 12:44 PM
SIXSLUG's Avatar
Have you checked your trailer wiring harness at the hitch?
They can get moisture and dirt in them causing the wires to coorrode and touch each other causing problems.
I'd start there.
Old Mar 14, 2011 | 12:46 PM
Cholmes's Avatar
Been all over that. It is in good condition,
Old Mar 14, 2011 | 12:47 PM
SIXSLUG's Avatar
Then I would go to the steering column and check the flasher switch and the turn signal switch.
Old Mar 14, 2011 | 12:49 PM
Cholmes's Avatar
Well the turn signals seems to be fine but I guess I will have to take apart the flasher switch or maybe unplug and jump the wires to see if it flashes ok
Old Mar 14, 2011 | 12:52 PM
SIXSLUG's Avatar
If the turn signals are working then the flasher relay is working at that point. I would bet flasher switch is munged up and nees cleaning or replacement.
Old Mar 14, 2011 | 12:54 PM
Cholmes's Avatar
Hope so as that sounds easy
Old Mar 14, 2011 | 12:55 PM
Cholmes's Avatar
I should mention it was a farm truck before I got it so there was plenty of hay seed and cow #@%$ everywhere so there might be a cow patty in there somewhere.
Old Mar 14, 2011 | 02:32 PM
SIXSLUG's Avatar
That's funny!
I know the window switches can get gunked up from dirt and water etc and a good cleaning usually will restore them. If there is junk in that switch it could cause it to act up.
Good luck!
Old Mar 14, 2011 | 02:34 PM
Lil Dog's Avatar
So the O2 units only use one flasher? Mine has 2 in the 97.
Old Mar 14, 2011 | 08:45 PM
zukota's Avatar
Yes, the 02 (or at least my 01.5) has 2. One flasher for the blinkers, one for the hazzards. Had me stuk for a while also. The 4 way flasher is the blue 'realy' looking square in the dash fuse box. ...Dealer only.
Old Mar 15, 2011 | 11:59 AM
SIXSLUG's Avatar
Where's the other one?
Old Mar 15, 2011 | 12:14 PM
high bid's Avatar
Next to the flasher fluid reservoir.
Old Mar 15, 2011 | 01:57 PM
SIXSLUG's Avatar
Will I need a bucket of steam to top it off?!
Old Mar 16, 2011 | 07:45 AM
high bid's Avatar
Ahhh, a good laugh
