Hard left pull
Old Jul 12, 2010 | 11:18 PM
tjs88yj's Avatar
Hard left pull
My truck is pullinghard to the left when under braking. Any idea what might be wrong?
Thanks Tom
Old Jul 13, 2010 | 12:52 AM
rattlerbob5.9's Avatar
Thanks Tom
A bad flexible brake line or a sticking/draging right side caliper that is getting hot and has reduced stopping power due to fade. Could also be you have a wheel bearing going bad.
Old Jul 13, 2010 | 04:01 PM
jcw74801's Avatar
Mine was pulling pretty good when I bought it. I cleaned and lubed all the moving parts and it has been stopping straight ever since.
Old Jul 13, 2010 | 07:08 PM
infidel's Avatar
Worn out track bar will pull when braking and is very common.
Have someone turn the steering back and forth slightly while you watch the driver's side joint.
If you see any play at all in the joint it's time to address it.
Old Jul 13, 2010 | 07:58 PM
STate's Avatar
I had the same issue earlier this summer, ended up being a bad front brake caliper. Replaced both sides with new calipers and have not had anymore pulling issues under braking.
jd1515
Dec 8, 2009 09:43 PM
xtoyz17
21
Dec 21, 2006 11:00 PM
MasseyMan1089
39
Mar 9, 2006 11:37 AM
Bobcat698
19
Nov 3, 2005 10:40 PM
Turbo Deeezle
Jan 20, 2005 06:46 AM
