GM wheel cylinders put in today........day and night!!!!!
Old Jun 26, 2004 | 09:12 PM
Turbo Deeezle's Avatar
Thumbs up GM wheel cylinders put in today........day and night!!!!!
Took me less than 2 hours ( with clean-up and garage floor mopping) It is incredible how much better it brakes now. $30 something vurses $600 for an exhaust brake is A-OK for me. I don't tow anymore, but I wanted to save myself the $ and headache of pads and every 6 months. THANK YOU to whoever gave the tip and NAPA part #'s........... I cant remember who it was. I am so stoked, now I can use the money I planned on buying Banks brake for more mods.
Old Jun 26, 2004 | 11:03 PM
Rattlerattle's Avatar
Kind of makes you wonder why they didn't come from the factory like that.
By far one of the best bang for buck upgrades.
Old Jun 27, 2004 | 11:34 AM
infidel's Avatar
Watch, everyone will start cracking their drums in half and sue me.
(Just kidding)
Old Jun 27, 2004 | 11:54 AM
J BODY's Avatar
.....or complain about not getting 150K miles out of there rear shoes any more!
Old Jun 27, 2004 | 05:29 PM
INJECTOR JACK's Avatar
Talking rear brakes
Just finished converting my Dads 98 s/w/b 2500 over, it came with 27mm wheel cylinders, but the 30's sure make a big diffrence.
Old Jun 27, 2004 | 07:54 PM
Dieseldude4x4's Avatar
The brakes on my son's 94 dually are terrible. I wonder if this would help it? We have put new cylinders, new shoes, and done everything you can imagine. It is still terrible and the pedal is like stepping on a plum every time.
What were the part numbers again or what were they?
Old Jun 27, 2004 | 09:18 PM
infidel's Avatar
Napa #4637337
Don't tell the Napa guys what the part is or what it's going on, it will just confuse them and you won't get the right part.
Just the above part number is enough. You can even order online by clicking here
Old Jun 28, 2004 | 02:10 PM
Got it, thank you very much.
Do they bolt right in or is there some work required?
Old Jun 28, 2004 | 02:37 PM
wheel cylinders
The wheel cylinders bolt right in, you don't even have to take the shoes off, you just have to remove the top spring and pull the shoes out of the way. It is a cheap fix, that works great.!
Old Jun 28, 2004 | 05:22 PM
PK's Avatar
PK
Did I miss something?
What are you guys doing?
GM? What gives?
Old Jun 28, 2004 | 05:44 PM
Putting a little bit bigger rear wheel cylinders on the rear end of the older trucks to make the brakes work like they should have from the factory.
Old Jun 28, 2004 | 06:28 PM
K2Cummins's Avatar
What years does this conversion benefit?
Old Jun 28, 2004 | 06:58 PM
(Just kidding)
Old Jun 28, 2004 | 07:50 PM
infidel's Avatar
All the way up till the rear disc brakes came out, '01 or '02???.
Biggest advantage is on pre '97 2500s where the cylinders were 24mm but on 3500s and all post '97 trucks (27mm, the largest Dodge used) you definitely see an improvement as the cylinders GM uses are 30mm. There was a post here where someone figured out the increase in braking force as related to cylinder diameter. I don't remember the numbers but the percentage increase per mm was quite impressive.
Old Jun 29, 2004 | 09:14 AM
Cowhand's Avatar
Has anyone figured out how to get the self adjusters to work?
