Fuel level sensor on module
Old Mar 14, 2008 | 10:38 AM
JARHEAD's Avatar
The float level sensor mounts on the module. Does it go up to the top of the rail or is it mounted down on the bottom part of it? There are two different spots it can go.
Old Mar 14, 2008 | 10:44 AM
nv_brewer's Avatar
I currently have mine apart and if I remember (it's at home) it's about a third of the way up from the bottom. I can take a picture this afternoon and get back to you.
Old Mar 14, 2008 | 11:09 AM
JARHEAD's Avatar
I appreciate it.
Kip
Old Mar 14, 2008 | 11:15 AM
JARHEAD's Avatar
Pretty sure it has to do with the size of the tank. Mine is a 35 gal. I thought the one i took out of my truck was in the upper notch. I just got my replacement module from the junkyard and it was on the lower notch. Just not sure which is correct.
Old Mar 14, 2008 | 11:23 AM
nv_brewer's Avatar
Mine is currently set to the factory position (35 gal tank) as I am in the middle of installing the 60 gal tank and haven't changed anything yet so it will show the proper setting.
Old Mar 14, 2008 | 09:23 PM
nv_brewer's Avatar
Here's the pic of mine. The tape measure is butted against the lip.
Moobesor
Feb 23, 2008 09:57 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
