Fuel Cap Question
Old Feb 24, 2004 | 02:39 PM
dodgediesel4x4's Avatar
Question Fuel Cap Question
Ok guys, how many turn(s) does it take to tighten yall's fuel caps? When I'm finished fueling my truck up and tighten the cap, it only takes about 1/4 of a turn before the "click" to sound, if even that. It just doesn't seem like that gets it tight enough to keep stuff from getting in there. I will then turn it several more times to hear more clicks, but that seems to not make it any tighter. Is this normal, or should I replace the cap?
Thanks,
Hunter
Old Feb 24, 2004 | 03:10 PM
firestorm's Avatar
That's all I get out of mine, is a 1/4 turn.
Old Feb 24, 2004 | 03:56 PM
amartinson's Avatar
Me too.
Old Feb 24, 2004 | 04:23 PM
blackjack's Avatar
Mines the same
Old Feb 24, 2004 | 10:56 PM
jrs_dodge_diesel's Avatar
If you look at how the cap is threaded and where it goes in the filler hole it looks like it fits. The cap is only there to keep the diesel in, crud out, and I think its even vented. A gas cap on a gasser vehicle is threaded to be non venting, for emissions.
Old Feb 25, 2004 | 01:55 AM
BigBlue's Avatar
I just stick mine on there. Don't turn it. Reason being is that whenever I used to tighten it, when I would take it off, I would hear air getting sucked into the tank. I didn't like that. It meant a vaccum inside the tank and that meant more work for the fuel pump. Not to mention, my gas gauge reacts a little quicker and I'm acutally getting a little better mileage.
Old Feb 25, 2004 | 08:33 AM
BigBlue, On the top of the tank there is a fitting that serves as a vent. Only thing is there is a cap on the vent left there from the factory. A number of our trucks had the cap left on. I believe there is even a TSB out for it. All you have to do is run your hand on the top of the tank and feel around for it, and pull it off. That should fix your problem.
Old Feb 25, 2004 | 10:27 AM
Heres what J.R. is talking about.
http://dodgeram.org/tech/dsl/ISB/low_power.htm
Go ahead, go out right now and check it in the rain!!!
Old Feb 25, 2004 | 12:47 PM
That's what I was talking about. Thank you for that link dodgediesel4x4.
Old Feb 25, 2004 | 03:58 PM
BigBlue's Avatar
That takes to much time and effort. I'll leave the cap off and maybe one of these days, when the weather clears up and quits acting all goofy, I'll deal with the plug. But until then, I'll just leave my cap unscrewed.
thumbs
Dec 27, 2008 11:32 AM
VFDFireman
Jan 5, 2008 06:47 PM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
TDIwyse
Jan 16, 2005 11:02 AM
