Front springs
Front springs
I was considering replacing my 02 2500 front springs which are currently 039/038, but when I went to the spring shop ( which by the way is a well respected place in my area ) they told me I had the heaviest that I could get. Is this true? I've been hearing numbers like 047/046, will these work? Also what would the benifeit be to adding the springs, i.e. will it carry more of the weight of my plow. Should I also replace the shocks with a better dampening type? The reason I'm considering this, is because I hang a Western MVP 8.6' plow off the front. The plow ways roughly 840#'s.
Re:Front springs
I don't know if those are the heavest factory springs or not.
But, have you considered the aftermarket skyjacker ones?
Seems like that might be a good option if you have a plow on the front?
RR
RR
Re:Front springs
I ordered my truck with the snow plow and camper package. It came with the 046/047 front springs. Go to http://dodgeram.org/tech/specs/springs.htm and you will get some front spring information for your truck. The higher rate springs will help you with your plow weight and raise the front a little. Good luck.
Guest
Posts: n/a
Re:Front springs
You can go here, where I bought them: http://mall.cyberdivan.com/acb/showd...490&DID=48
If you look the photo of the 2.5" lift kit, those are the springs. Check the part numbers below and you'll see "D25" in the string. National Tire & Wheel will sell you the coil springs alone without the kit, but you'll have to call them.
I.
I.
Jordan5687
Jan 29, 2015 10:32 AM
53 willys
23
May 19, 2008 06:14 PM
95turbo4wd
Dec 12, 2007 05:59 PM
holeshot440
Apr 15, 2007 05:59 AM
