Front shock removal
Thanks to all who contributed. Your timing is impeccable.I just installed the rears yesterday. And i thought i'd need a spring compressor for the front. It's still up on the rack so i'm back at it this morning. YOU GUYS ROCK...Thanks!
So who likes their billstien yellows? and does not think they are too harsh. I'll not be able to drive it till my trans is done. ([$2200.00 in pars and running...)
I cant wait
I cant wait
I can't remember the code 1748...or something like that. It slips up to 2000RPM and does not really lock-up. starts to around 30mph...then really locks up around 50MPH. This may have been the problem all along. Keep in mind this is TRANSMISSION # 9 !! (not kidding)
Something about the tcm/ecu problems.
This is the first trans. i am replacing at my expense. So i bought the RED clutch pack kit. DTT throttle body. voltage regulator.Input shaft, HD torQ converter. I added a Derale fan cooled trans cooler, and a B&M oil pan +4 Qts. ....Yadda Yadda, Yadda....
So maby it was just an electronic problem all along.
I just did mine and the front fixed lower nut started to spin on the drivers side. I had to put it on a lift to let the front end weight stretch the spring and get the mig welder in there to weld the nut in place so I could continue to back out the bolt with the impact. It was like freakin' brain surgery. I also had to torch the shock shaft in half to get it out as the top nut wouldn't come off and i couldn't get it past the battery tray. It was easier than removing the tray.
freight train
22
03-25-2013 04:46 PM
jeephauler
04-11-2012 11:58 PM
lv2bunderwater
04-20-2011 08:20 PM
stumpjumper
08-21-2007 07:14 AM
