Front end woes.
Old Jun 13, 2005 | 12:44 PM
ddrose734's Avatar
Unhappy Front end woes.
Just wondering if anyone has had there tierod ends worn out at 100,000 miles. I have a 2001 4x4 with cummings and the tierds have allready worn out. I dont do much offroading so that is not he issue. I did go to one size larger tires but dont think that is problem. At 80,000 mi the sterring gear box stated to leak at 86,000 had to reeplace it because the input shaft almost fell out,(what the dealer said anyway).
Old Jun 13, 2005 | 02:17 PM
Mechanos's Avatar
tsk tsk tsk..... the cardinal sin has been committed once again....
Old Jun 13, 2005 | 06:32 PM
mkubacak's Avatar
Amazing isn't it. It is printed on both doors of my pickup. Maybe his has a factory defect?
I have seen posts of people replacing much more much earlier. So, your results may vary.
I have all of my orginal steering and suspension components. I am looking at a DSS and a 3rd Gen trackbar though.
Old Jun 13, 2005 | 07:48 PM
Scubasteve's Avatar
Inner drag link and an 02 track bar at 40k miles.
At 60k miles it needed another inner drag link and outer tie rod end. At this point I bought new parts and put grease zerks in every fitting and also drilled the lower ball joints.
210k miles I replaced all the steering linkages again plus a new track bar( I was stunned that after 150k miles the track bar was well within spec but changed it anyways since I had bought one).
You know there is something wrong when you can replace all the steering componants and not need a alignment, she was spot on..
I need to get the pitman arm off so I can do the seals and I also ordered a DSS so that should fix things up pretty good.
I must say that the ball joints have been amazing, they have a bit of vertical travel in them but no lateral play at all and are original..
Jason
Old Jun 14, 2005 | 10:17 AM
Dshiftff's Avatar
Hey scuba, do you have a link to the DSS website you mentioned? Thanks....
Old Jun 14, 2005 | 05:05 PM
phox_mulder's Avatar
I got my DSS from http://www.solidsteel.biz/ ordered from Rip at Source Automotive in Oregon.
phox
Old Jun 15, 2005 | 09:01 AM
Dshiftff's Avatar
Thanks, Phox.
kertoncol
Oct 23, 2007 09:11 PM
samahi72
Jul 23, 2007 04:15 PM
samahi72
Jan 18, 2007 02:20 PM
SuperDave4x4
Nov 2, 2005 07:11 PM
Gordonville
Apr 18, 2005 09:45 AM
