front axle
Old Sep 6, 2005 | 08:20 PM
kw power's Avatar
front axle
hay i have a quick quiesttion i though i read in a 4wheeler mag that the dana 60 front axle on the 2nd gen if you put lockout on the hubs and put it under tourqe you will break the axle cause it is a smaller 32 or 28 spline and not a 35 is this true and can any oun tell me what needs to be done so this does not happen and can still ues loctets? thanks for your help
Old Sep 6, 2005 | 08:24 PM
phox_mulder's Avatar
What year truck?
phox
Old Sep 6, 2005 | 10:12 PM
yarddog's Avatar
2nd gens have 32 spline axles. Don't worry, if your not locked in front and aren't running huge tires they'll be hard to break.
If you want to ugrade to 35 spline you'll need a locker with side gears to take 35 spline inners and the spindle will have to bored out to take a 35 spline outer. Then new hubs. While you're at it throw some CTM or Longfield u joints in them and forget about it. I've worked on old 60's but nothing as new as a 2nd gen so I don't know how to deal with the CAD if you have it. I don't know if can be by passed or what.
If you engage the CAD, it's no different than if you engage lock outs. Unstead of lockouts these axles use drive flanges so the axles turn all the time. It only matters if you put a locker in it.
Check out this article on the 35 spline upgrade:
http://www.pirate4x4.com/tech/billav...ine/index.html
Old Sep 7, 2005 | 03:24 PM
shawn085's Avatar
I don't know how strong you want it to be but this might answer your question. Go to dynatrac.com they make larger axels, a long one piece axle for the right to eliminate the CAD, and Ford style locking hub kits that make the wheel bearings serviceable and stronger for larger tires. In total they can make the front axle very strong but it is not cheap.
Old Sep 7, 2005 | 04:40 PM
NHDiesel's Avatar
Don't use CTM joints if its a street truck. They have awesome strength, but aren't designed for long term wear in a daily driver street vehicle.
Jim
csramsey640
Jun 4, 2014 10:31 PM
rustydeeretech
17
May 21, 2011 03:05 PM
case310350
Jun 23, 2010 09:03 PM
Hawkeye
Apr 29, 2008 10:24 AM
Paul Winey
Jun 22, 2004 08:09 AM
