Electrical problems?
Old Apr 19, 2019 | 07:57 AM
B.boothe's Avatar
Okay, it’s without load and I’m not sure where it’s losing oil I think it’s burning it off. The temp gauge used to work and if it still does then it’s around 140° 150°.
Old Apr 19, 2019 | 10:43 AM
jstapler313's Avatar
oil loss
Hate to say this, but could be turbo. I can't tell u how to troubleshoot it, but I'm sure these guys can steer you straight. The reason I say that is because I thought I had blown my eng, smoke billowing out the exhaust. Thought I blew the eng. It was only the turbo. Be careful it can drain your crankcase and in some cases start burning eng oil and Run Away. BTW be proud, you decided to tackle something that many grown men would not
do. Congrats on your spunk. Semper Fi.
Old Apr 19, 2019 | 06:12 PM
AlpineRAM's Avatar
Well, OK, no oil leaking out, so it must go somewhere- check radiator, maybe the oil goes there. If not, it is probable that it gets burned.
How about coolant- level OK, unchanging and not contaminated?
Maybe it still is the turbo as jstapler313 suggests. Simple test would be to remove the turbo, plug both oil lines and run the engine to 2000 rpm- no change your turbo should be good, works fine- turbo or install problem
Old Apr 21, 2019 | 11:14 AM
SIXSLUG's Avatar
White smoke is usually coolant burning... Temps won't really come up unless you are running under load so your temp gauge is probably ok. As stated head gasket can be done in vehicle. There is some good you tubers like deboss garage that are well informed....take a watch or two and see if you feel up to the task. You are taking good steps toward diagnosing your issue rather than just throwing parts at it like many do around here. I'm eager to see you up and running!
Kurt
Old Apr 30, 2019 | 05:33 PM
B.boothe's Avatar
I think there is oil in the coolant and coolant in the oil, I checked the turbo and it’s all good, but I’m definitely losing coolant and oil, and I think they’re mixing together and then burning off, is that possible? If thats the case what do I need to do?
DJ Turbo.
Oct 13, 2011 09:11 PM
David Kee
Oct 11, 2003 08:33 AM
FastSS
Sep 8, 2003 01:47 AM
FastSS
Jan 8, 2003 05:53 PM
TurboAZ
Oct 11, 2002 12:34 AM
