electrical problem
electrical problem
a while back my front window was leaking water on the fuse box and causing things to turn on and off. before i figured it out it turned things on and off so much it over heated something and now my dome lights, radio, and power mirors dont work. anyone have a guess on what i might have burned out. i cant find any blown fuses in either fuse box. i replaced my ignition switch and headlight switch but it made no diffrence. oh and it always thinks my door is open for some reason.
I know you checked for fuses, but there are 2 fuses in a yellow plastic lock, in the fuseblock inside the cab to the left of the steering wheel. I remember overlooking them before when I had the same problem.
